Diagbox/lexia drivers not working/not installing
Qylian
Post by Qylian »
Hi everyone,
We're having issues getting diagbox/lexia working and are stuck after multiple reinstalls/updates.
Setup: Windows 7 professional 32-bit (x86)
Diagbox initially installed as v7.01, then updated to v7.58 with given update files.
We are using a PSA XS Evolution clone (921815B)
Car to diagnose: 1994 xantia
When we open diagbox and select citroen, xantia, it then says to plug in the VCI. After we plug in the VCI it still doesnt find the VCI, and when we look at device manager it says that there is an issue with the usb drivers. When I went back to the installer and extracted the driver installer and files, I ran the installer and it says that the driver pre-install was succesful. When replugging in the VCI, it still doesnt want to work.
Does someone maybe have the driver install files that we can use? Any help would be appreciated.
Thank you in advance :)
x 8156
Re: Diagbox/lexia drivers not working/not installing
Post by mickthemaverick »
Have you been able to use the VCI on other vehicles? :)
Qylian
Post by Qylian »
mickthemaverick wrote: 07 Jul 2026, 09:15 Have you been able to use the VCI on other vehicles? :)
Yes, I was able to use yhe VCI with diagbox 9.85 (windows 7 64 bit) on a berlingo (B9)
x 8156
Then it may be that the VCI will not communicate with the 32 bit software. maybe you need to find an older VCI to use with your 32 bit system? Only a suggestion with no experience to back it up! Good luck :)
Qylian
Lexia not correctly initialised
Post by Qylian »
Hello,
I'm trying to read out my xantia '94 with my clone VCI. I was able to read out my berlingo with it using diagbox 9.85, so I know the VCI works. Now I have a new laptop with windows 7 32bit and diagbox 7.58. I installed all the drivers needed to make the usb serial communication possible. When I plug in my VCI and launch diagbox, I select citroen, xantia and then when it asks which tool I would like to start (lexia/scantool) I remove the vci usb, wait 5 seconds and plug it back in. I then select lexia and get this screen. I also tried it without removing the usb, but we get the same result.
I also measured the voltage coming into the VCI adapter and measured 12.3V.
Does anyone have any experience with lexia and this screen?
Any help would be appreciated, thank you!
x 8156
I have moved your post today to the thread you already have on this subject to avoid duplication, :)
