XANTIA HDi RUNNING ROUGH
Onlinemyglaren
- x 5674
Re: XANTIA HDi RUNNING ROUGH
Excellent result, just some minor niggles to clear up left
Huskyxantia
- x 921
Brilliant news very very pleased for you
Husky.
Skull
- (Donor 2026)
- x 382
LHM+ Leak fixed (octopus leg return from front height corrector trimmed and re-joined with 3.5mm x 7.5mm - originally 9.5mm)
Dip stick bodged
A bit more smoke when engine warmed up
Fans operating around 97?
Just waiting for the ABS rings to arrive, once fitted I can get the driveshaft back in, gearbox oil, then lower her down to earth and shuffle her around the driveway to try and let the sun clean up the blocks on the driveway
I haven't done a Compression test yet but after a bit of Citrobics and a top up of LHM+ a missing Exhaust cup washer pinged onto the floor (from height corrector cradle
Sounds OK to my untrained DIY ear
Still missing:
1x Exhaust manifold nut 13mm
1x Exhaust joint nut from Cat pipe 10mm
1x Glow Plug nut 7mm
Dip stick bodged
Still missing:
Gary
Gary
- x 1997
Huskyxantia
- x 921
Excellent top job
Husky.
Skull
- (Donor 2026)
- x 382
Well today was it’s proper road test after doing both front ABS reluctor rings and re-filling the gearbox with oil…..
It’s still smoking like anything, it starts easily, sounds smooth even when revving and feels like it’s got the power it should have BUT still smoking HEAVILY
(to a dangerous visibility level).
I’m going to do another compression test and then try listing it on eBay before the insurance runs out on the 18th June …I’ll drive it into the scrap yard
SHOUT if you want anything…
Gary
Gary
- x 8143
Black, blue or white smoke Gary?
Might I suggest a diesel cleaner through the system before you send it to the car park in the sky, have a look through the options here: https://low-offset.com/workshop/best-turbo-cleaner/
Skull
- (Donor 2026)
- x 382
Little bit of blue then lots of white
New cylinder head gasket (twice) but still smoking ...
Poor dash cam quality made worse as it wont connect to my laptop so recorded it on my phone (driver problem) sometimes everything is fighting me
Gary
Gary
- x 8143
White is unburnt fuel so perhaps the fuel system needs checking over as it may be overfuelling?
moizeau
- x 423
Might be worth doing a leakoff test to see what the injectors are doing. No special equipment needed apart from some pipe and 4 jam jars.
Pete
Huskyxantia
- x 921
Sounds like over fueling
Husky.
Skull
- (Donor 2026)
- x 382
Gary
Gary
Huskyxantia
- x 921
How far has it been for a run , also do these have a cat ? If so has it failed.
Husky.
Skull
- (Donor 2026)
- x 382
Only a few laps of the block ... I daren't take it for an 'italian tune-up'
Has a cat fitted but doesn't actually need one ....
I don't think it's failed
Gary
Gary
Huskyxantia
- x 921
I'd say over fueling then , if you do a leak off test as someone has already mentioned that might rule it out if its not over fueling, what about timing is the fuel pump to advanced ?
Husky.
