Injector torque
Zsolo1
Injector torque
Unread post by Zsolo1 »
Hello!
I need help!
How to tighten the injector clamping screw of a 2015 Citroen c4 picasso 2.0 HDI, or how many Nm should I tighten it with?
Screw size M8
Delphi injector
Engine DW10FD
Thx Zsolo
x 8067
Re: Injector torque
Zsolo1
Re: Injector torque
Thank you!
Do you think the injectors on the two different engines should be tightened the same way, even though one is Bosch and the other Delphi?
DW10FD vs DV10TD?
x 8067
Re: Injector torque
As I understand it the difference between those engines is in the emissions control so I would expect them to be the same torque settings for the injector clamps. :)
Zsolo1
Re: Injector torque
I read somewhere that the Delphi injector must be pre-tensioned with a minimum torque ("X" Nm), and then secured to the appropriate degree with a protractor. The difference, according to my information, is that the Bosch works with lower pressure. That's why there is a different procedure.
x 8067
Re: Injector torque
Fair enough you already know more about them than me! :-D
Zsolo1
Re: Injector torque
DW10FD (2.0 BlueHDi – modern Delphi)
Clamping bolt torque: ? 7–9 Nm + 65–75° tightening
(typical: 8 Nm + 70°)
DW10TD (older 2.0 HDi)
Clamping bolt torque: ? 7 Nm + 60–65° tightening
Unfortunately, what I know is not official...
