That's why I said 'fairly well'
Peugeot 207 1.6hdi (New edition to the fleet)
- x 8218
Re: Peugeot 207 1.6hdi (New edition to the fleet)
Huskyxantia
- x 820
Gaps Jim i know what you mean by that lol
Husky.
Huskyxantia
- x 820
I tackled the rear wheel bearing took 2 hrs was a bit of a faff my press didn't have a perfect fit for the one in it but it came out , pressing one back in was easy as I used the out case of the old bearing which I've built up a little collection of over the years and do come in very handy as there perfectly sized. How ever .... the noise is still there , im now thinking either the new shock is naff , or , filler neck pipe possibility of that hitting wheel arch liner , and another grrrrr , part of the lip the wheel sits and slides over broke off ! Ffs moment now I got to buy a completely new drum all that effort for nothing
todays been crap. Went to get some items in a shop this morning self check out didnt want to play ball , young shop assistant was a useful as a chocolate tea pot he could see something was wrong and just stood there looking like a butterfly has just flown past him, so I shoved the trolly to him said stuff that and went else where , cant be doing with it
Husky.
Huskyxantia
- x 820
MattBLancs wrote: 11 Jan 2026, 19:03Sorry drum maximum inside diameter or shoe friction material thickness?Huskyxantia wrote: 11 Jan 2026, 18:52 Anyone know the thickness the brake drum should be ? Untill they need new ones ?
Sorry I haven't a book of lies for 207, if they've carried over same drum setup as the 206 uses, then here's the figures from Haynes:
Not sure if I've measured wrong he's my effort
250mm outer
225mm inner
220mm face
How do them numbers sound ?
306 has
New 180mm to max 181mm or Bendix new 228.6 to max 230 mm
Shoes new 4.85 mm to minimum 1.5 mm
Husky.
Huskyxantia
- x 820
250mm outer
225mm inner
220mm face
250mm outer
225mm inner
220mm face
Husky.
Huskyxantia
- x 820
Plenty of free play with hardly any effort to make it move and wiggle till it pops off part of itself, top photo completed task
Husky.
Huskyxantia
- x 820
Bushfix a pair of long nose pliers to make it fit the retainer clip
Funny thing was the proper pair I have snapped at the most important point so this rendered them useless.my bushfix did the job
Husky.
PaulC5
- x 644
225 mm ID sounds like a 9 inch drum. Our 2010 C3 had that size and it had a hub nut with a built in washer and 300 Nm torque setting with a bit of grease on it.
Huskyxantia
- x 820
Sounds the same my hub nut has the same set up. 300nm yes and domt i know it my poor back
Husky.
Huskyxantia
- x 820
Husky.
Huskyxantia
- x 820
Had it confirmed as correctly fitting my car so a new unit was then purchased and will be here in a couple of days.
Husky.
Huskyxantia
- x 820
Even though the wheel bearing was replaced and a part of the hub fell off i was able to get the wheel on and bolted up , gave it a wiggle after to check if there's play , none . The new one should be here couple of days £56... not to bad. Most annoying is ive still got this noise it sound like plastic , filler kneck might be hitting the wheel arch liner ? Next free time ive got im going to put the original shock back on to rule out that , then while there check again the fuel filler kneck . Update will follow in a few days.
Husky.
PaulC5
- x 644
I did not have a torque wrench that went up to 300 Nm so got a Machine Mart digital torque adaptor https://www.machinemart.co.uk/p/040215238/ After I realised another one I had went close enough and used that, again with the pipe on it. To undo the nut needs a long wrench, I have an 18 inch breaker bar and then a bit of pipe to go over it to make it longer. Possibly a 36 mm 6 point impact socket used.
Huskyxantia
- x 820
I still use my old big long breaker bar with a scaffolding pudlock slipped over the top , think i was told a while back the a shoulder of the hub nut itself equal about 75Nm so I torque up first 200Nm with the wrench ,then work out a marker to tighten this shoulder part of the hub nut and then long bar with scaffolding pole ,pole 3 feet long , nip the thing up in line with the marks I make and in my mind I think ok got a tad more , then thats it im where I need to be , you sort of feel its ok
Husky.
- x 2252
Perhaps consider one of these:PaulC5 wrote: 09 Feb 2026, 21:07 To undo the nut needs a long wrench, I have an 18 inch breaker bar and then a bit of pipe to go over it to make it longer. Possibly a 36 mm 6 point impact socket used.
viewtopic.php?p=808778&hilit=Breaker+bar#p808778
18" is 450mm, think my half inch drive breaker bar is 600mm (24")
However that 3/4 inch bar is 39"
