Fuel cap solenoid replacement
Newpicman
- x 3
Last couple of times I've fuelled up I've had problems with the filler cap not locking or unlocking properly. I suspect it's the solenoid. Does anybody know a tutorial for replacement and also the part number for the part.
My car is a 2015 C4 Picasso hdi blue.
Thanks for any help and replies.
- x 8084
Re: Fuel cap solenoid replacement
Unfortunately your car is too young for the parts diagrams I have access to but hopefully someone will help you out.
Newpicman
- x 3
Fingers crossed, Ty anyway Mickmickthemaverick wrote: 12 Jan 2026, 17:44 Unfortunately your car is too young for the parts diagrams I have access to but hopefully someone will help you out.![]()
Mihael_M
- x 36
Look here, it has already been written.
https://frenchcarforum.co.uk/forum/view ... ries:%2037
Newpicman
- x 3
Many thanksMihael_M wrote: 12 Jan 2026, 18:21 Look here, it has already been written.
Newpicman
- x 3
Just wondering if anybody knows the correct part code for the solenoid?
TIA
TIA
Mihael_M
- x 36
No. 15 from the picture, which is Peugeot Nr. 9810871780 .
https://www.amazon.co.uk/9810871780-Dri ... B0F267ZQZ1
Newpicman
- x 3
Thanks, saw that but also saw part number 9678313180 also for mk2 c4 picasso. Didn't want to order the wrong one, is there a way of knowing it is definitely the 780 one without removing the old one?Mihael_M wrote: 12 Jan 2026, 21:37 No. 15 from the picture, which is Peugeot Nr. 9810871780 .
Huskyxantia
- x 900
Husky.
Huskyxantia
- x 900
Husky.
Huskyxantia
- x 900
I found a couple of videos not sure if there be of any help , but might help others at later dates or so on
Husky.
Newpicman
- x 3
Many thanks will check them out later when I'm back home.Huskyxantia wrote: 13 Jan 2026, 00:52 I found a couple of videos not sure if there be of any help , but might help others at later dates or so on
Mihael_M
- x 36
According to the instructions from this post, uninstalling is easy. Since it doesn't work remove it now to be sure what you should buy.
Newpicman
- x 3
Yep will do Ty.Mihael_M wrote: 13 Jan 2026, 07:07 According to the instructions from this post, uninstalling is easy. Since it doesn't work remove it now to be sure what you should buy.
Newpicman
- x 3
Thanks everyone for the replies. Had a look and the solenoid is working ok. The problem is the push button to the left hand side. Can't spray no wd40 as it's got a rubber seal around it. Tried pressing in and out plenty of times, odd now and again it stays at the pressed in position and vice versa. Will keep my eye on it and possibly take apart to access from behind the rubber and spray some lubricant.
Thanks again everyone.
