Lucas EPIC Injection Pump Overhaul Guide
Peterr
Re: Lucas EPIC Injection Pump Overhaul Guide
Unread post by Peterr »
Thanks for the manual!!!
Having the same leaking Lucas issue🙄
Segansa
Unread post by Segansa »
CitroJim wrote: 04 Nov 2016, 12:48 You need to prime it first.... Get it full of diesel before making any attempt to start...
Hello sir, I know that this post of yours was almost 10 years ago, but if you can still help me, if you remember the details of “priming” that pump?
How do you get diesel in it?
I’ve fitted mine in, cranked it a lot by now, not aware i was supposed to prime it, but no fuel is coming out of the fuel lines of the injectors..
Rhothgar
(Donor 2026)
x 221
Unread post by Rhothgar »
Segansa wrote: 17 Feb 2026, 16:17
Normally these pumps have a rubber hand pump for manual priming. This is certainly the case for my partner’s ZX.
Basically pump that until it has good resistance. Sometimes it helps to have an assistant who can pump the bulb whilst the car is being cranked.
x 8365
^^ Yep, that's it :D
moizeau
x 429
Unread post by moizeau »
To add, with the ignition turned on to open the electrovalve to allow the diesel to flow
Pete
Rhothgar
(Donor 2026)
x 221
moizeau wrote: 18 Feb 2026, 07:02 To add, with the ignition turned on to open the electrovalve to allow the diesel to flow
Very good point!
Segansa
Rhothgar wrote: 17 Feb 2026, 21:13
Thats really strange, mine doesn’t have any rubber pumps, on the pump itself nor on any of the hoses..
Also my question is, since Ive had the pump opened, do those pumps have their own timing?
For example the position of the drive shaft and the rotor.. Does it matter how it is aligned?
Also, could I attach a rubber pump anywhere to help extract all the air outside of the pump, and where would I put it?
x 2337
Unread post by MattBLancs »
Picture tell a thousand words!
From Google images
From Google images
:-D
Rhothgar
(Donor 2026)
x 221
Segansa wrote: 23 Feb 2026, 12:31
If you have taken the pump off and reinstalled then it needs timing. I am pretty sure. Someone else may confirm this.
If that turns out to be the case, I would argue that if you didn’t know this and took it off the car then the chances of you getting it working again are slim. You’ll need to get it to a diesel specialist and get them to refit the pump and time it.
I have all the tools for doing it but it is a specialist job which can be done by the home mechanic but it’s a bit a job I would take on readily.
x 2337
To my knowledge the (XUD9 and) XUD11 Pumps are on a bracket with slots, timing can vary by rotating the pump on the slots, so yes that should be set up.
I believe theres a bolt that comes off the end of the pump, into the hole that is revealed allows a rod to be inserted, a dial indicator lets you time the pump and hence do the adjustment.
However! I also recall Jim describing "tuning it by ear" - adjusting the pump with it running and setting it when it sounds, well, right!
Let me dig see if I can find it again.
Not a quite from Jim, but Wheeler also very knowledgeable. Mentioned here:
viewtopic.php?p=582699#p582699
(Still digging)
Rhothgar
(Donor 2026)
x 221
MattBLancs wrote: 23 Feb 2026, 19:10 To my knowledge the (XUD9 and) XUD11 Pumps are on a bracket with slots, timing can vary by rotating the pump on the slots, so yes that should be set up.
(Still digging)
That's exactly right. There is knurled nut from memory and you remove and stick your DTI in. A diesel specialist can do it by ear. My understanding is Van Gogh was not particularly good at tuning Citroens.
