Guide to Replacing the NG4 Navidrive 3D Hard Drive with a CF Card
This unit is the NG4 system, made by Harman Becker.
Main Features: DVD, Voice Commands, HighRes Display, 3D Mapping, Bluetooth Hands Free, Independent Phone with MDS Module, SD Card, USB, Jukebox.
x 1955
Re: Guide to Replacing the NG4 Navidrive 3D Hard Drive with a CF Card
Post by Paul-R »
I asked on GPS Power for you and someone (thanks gigidel) gave me this link. Firmware N42c.
https://mega.nz/file/FPRGHIBK#Ri3xD4dVZ ... 3um7F89O5s
Usual disclaimers. Use at your own risk, etc.
H4wkeye
(Donor 2022)
x 14
Post by H4wkeye »
Cheers mate. :D
PFG_FCF
Post by PFG_FCF »
giggle_crunch wrote: 03 Mar 2025, 17:54 Moving on with my 3 minute uptime problem 🙂
Noticed an interesting thing today during those 3 minutes, while the system is up and running but no sound output from radio, USB or disc.
So here's the thing: not all user data survided the rebooting, in particular all sound settings are reset to defaults (fader, bass, loudnes, etc.).
Moreover, it's not possible to set any sound settings during those 3 minutes, e.g. "Mute rear speakers" or "Loudness" (which must be controlled by the amp). What's happening: trying to tick the setting "Mute rear speakers" and the tick does not persist (appears on the screen for a second and then gone). Same when trying to set "Loudness". On the other side, "Speed dependent volume" can be set or unset with no issues.
Soo, I am wondering if there's a way to bypass the amp without much hustle.
Hello there, I started having the very same "3 min and reboot with no audio" problem after 15+ years.
Was this exact type of malfunctioning root caused eventually?
I have replaced HDD with new one, no difference.
Firmware upgrading attempts from USB (and SD ) to 42c fails immediately to error code 0x3000.
Any idea/suggestion/advice or recommendation appreciated. Many Thanks
kieding
Post by kieding »
Bonjour à tous,
Mon disque dur est tombé en panne pendant la mise à jour vers la version 8.31 sur mon Magneti Marelli RT5 (Citroën C4, 2009). Je vais remplacer le disque, mais malheureusement je ne peux pas accéder à l’ancien pour le cloner.
Si quelqu’un possède une image complète du disque dur (ISO ou clone) provenant de son propre RT5 et accepterait de la partager, je lui en serais très reconnaissant. Un lien de téléchargement ou même un CD/DVD gravé serait parfait — je prendrai bien sûr en charge les frais.
Merci d’avance pour votre aide.
Cordialement,
Tonny Kieding
x 5689
Post by myglaren »
Welcome to the forum but please write in English.
Unexpected to see someone from Norway writing in French.
If you are not confident enough to write directly in English then make use of a translator, Google Translate or as below, DeepL
Hello everyone,
My hard drive crashed whilst updating to version 8.31 on my Magneti Marelli RT5 (Citroën C4, 2009). I’m going to replace the drive, but unfortunately I can’t access the old one to clone it.
If anyone has a full image of the hard drive (ISO or clone) from their own RT5 and would be willing to share it, I would be very grateful. A download link or even a burned CD/DVD would be perfect — I will, of course, cover the costs.
Thank you in advance for your help.
Kind regards,
Tonny Kieding
Translated with DeepL.com (free version)
KosyoBosyo
Post by KosyoBosyo »
Hi to all. Recently bought an C5X7 with NG4 and Hiaudio. Problem is at random - rebooting. I tried at cold weather (14 celsius outside temp) and very hot summer (around 34 degrees). Reboot is not affected by outside temp or audio level. I tried to replace hdd with CF card, but found only 8gb on reasonable price and to clone the hdd we need at least 40gb for all the partitions. I fully disassembled the unit and found old thermal pads that i replaced. I will try to resolve the problem like this and if it work's - will confirm in a later post.
Red ones are before and blue after replacement.
KosyoBosyo
Update
System is rebooting far less than before. But still reboots. I read in a russian forum that there is a chip under the hdd that is limited to around 60degrees celsius and gets toasted overtime. Until I find the replacement chip to buy, I’m thinking of upgrading the fan inside.
