Evaporator sensor replacement
some1else
Unread post by some1else »
Hi,
could anyone help me locate the evaporator sensor on my 2000 xsara? The part number is 6445HF.
I've looked under the glove box and behind the central console, but I was only able to find 2 interior temperature sensors (654464W).
Thanks in advance!
x 1475
Re: Evaporator sensor replacement
Unread post by xantia_v6 »
The best I can find is:
The shape of the connector implies that it clips into the housing somehow, maybe you need to remove the housing to get access?
some1else
Thanks! The sensor is now replaced, but Lexia still shows evaporator sensor fault under ECU... Wires are in good condition. Any ideas?
some1else
Symptoms are: when heating knob is set even at 18C, and direction set to windshield, then the fan runs at full speed and blows as hot air as possible. When the direction is moved to blow front and feet, then the temperature regulation and fan speed are OK...
x 1475
some1else wrote: 15 Oct 2025, 06:01 Symptoms are: when heating knob is set even at 18C, and direction set to windshield, then the fan runs at full speed and blows as hot air as possible. When the direction is moved to blow front and feet, then the temperature regulation and fan speed are OK...
That may be normal behaviour?
some1else
You might just be right, after all there isn't a separate button for defrosting windshield... Thank you!
