- x 8144
Re: Must be me
Always good to see a C5 replace those!!
- x 3296
Re: Must be me
It might be that you are right in that there is a height imbalance. I don't have the information to check the correct ride heights (as this is an X7 C5), but I believe there will be a way to measure the ride height (front and rear) and then (using a Lexia, if the imbalance is slight) to re-set the correct heights.
stu9
- x 5
Re: Must be me
They are still good cars and better made than the C5.
Richard_C
- (Donor 2026)
- x 235
Re: Must be me
I had the steel sprung 2.0 163 bhp one for 6+ years and still look back on it as one of the very best long distance cars I ever owned.
For the 'proper' suspension this looks to be a simple, if unscientific, quick fix. The ramps are imporatnt though, adjusting ride height from underneath might have some risks
Richard_C
PaulC5
- x 698
Re: Must be me
Before you jack the car up you need to read this topic (if not already aware) which says to raise the car to max suspension height and then slacken the lds tank cap until the wheels are back on the ground. Something similar is in the handbook but could easily be missed and might not mention the cap.
viewtopic.php?t=62058
You should also not go underneath it without using axle stands or ramps since if a suspension height sensor is knocked or being worked on the car can quickly drop to a low level and squash you.
wurlycorner
- x 271
Re: Must be me
Tourer or Saloon, out of interest?stu9 wrote: 03 Oct 2025, 17:37 I have just got an old C5 X7 3.0 diesel and while it is very comfortable i find it to floaty but I am coming from an old C class and E46.
Iain
CX DTR T2 Safari (silver)
Iain
wurlycorner
- x 271
Re: Must be me
Ah I’m not on Facebook. Could you possibly provide a link to the advert please (I may be able to view it as a non member, who knows)
Iain
Iain
stu9
- x 5
Re: Must be me
I probably could but if you are not on it you probably won't see it.
PaulC5
- x 698
Re: Must be me
Maybe you could copy and paste the advert on here.
