Where should this plastic part be installed on the Citroen C5 II MK2?
sydo
- x 9
- x 8130
Re: Where should this plastic part be installed on the Citroen C5 II MK2?
This is the exploded diagram showing your piece. It looks like it is a shield for the lock operating rod but that is only my interpretation. Hopefully you can figure it out from there:
sydo
- x 9
yes right thank youmickthemaverick wrote: 03 Oct 2025, 11:47 This is the exploded diagram showing your piece. It looks like it is a shield for the lock operating rod but that is only my interpretation. Hopefully you can figure it out from there:![]()
C5 II - 0601 07 842701A - REAR HINGED SIDE DOOR CONTROL.pdf
sydo
- x 9
- x 3296
From your initial perspective maybe not. If, however, it prevents things dislodging that rod (which may then stop the door opening from the outside, for example)...sydo wrote: 04 Oct 2025, 18:12 I installed the part but I don't think it's a very useful or functional part.![]()
