Knocking at the back
widget
there is a knock when i go over bad parts of the rd wich is more than good rd i have seen a post some where but cant find it now i have not looked yet can some one give me an idea what it might be
D.Slatford
- x 1431
- x 1431
It's here:
http://www.andyspares.com/discussionfor ... IC_ID=1699
Actually in the Common Problems and Fixes section.
zzf00l
Can't believe I have just read this post... have just come in from adjusting mine, it's been driving me mad.... but I adjusted the two bump stop and achieved the same results.D.Slatford wrote:You forgot to say what car you have, but the Xantia's I've had were prone to loose boot latches - just a fraction, but enough so there's a few mm play in the boot which becomes more obvious over bumps. Adjusting the latch bolts so it closes tighter fixes it.
Sutton Coldfield, West Mids
Xantia V6 Exclusive (2000
Xantia 1.9TD SX (2000)
Previously owned
Xantia V6 Exclusive (97)
XM V6 Exclusive (95)
AX 1.4
Previously owned
AX 1.4
