Knocking at the back
widget
Unread post by widget »
there is a knock when i go over bad parts of the rd wich is more than good rd i have seen a post some where but cant find it now i have not looked yet can some one give me an idea what it might be
D.Slatford
Unread post by D.Slatford »
You forgot to say what car you have, but the Xantia's I've had were prone to loose boot latches - just a fraction, but enough so there's a few mm play in the boot which becomes more obvious over bumps. Adjusting the latch bolts so it closes tighter fixes it.
widget
sorry it is the ZX
x 1431
It'll be the rear subframe mounts. There's an excellent post in the hints and tips section that tells you how to change them. Just about to order a set for my wife's ZX.
widget
nx for help i will look for post
x 1431
It's here:
http://www.andyspares.com/discussionfor ... IC_ID=1699
Actually in the Common Problems and Fixes section.
widget
Just printed it out many thanx Richard
zzf00l
Unread post by zzf00l »
D.Slatford wrote:You forgot to say what car you have, but the Xantia's I've had were prone to loose boot latches - just a fraction, but enough so there's a few mm play in the boot which becomes more obvious over bumps. Adjusting the latch bolts so it closes tighter fixes it.
Can't believe I have just read this post... have just come in from adjusting mine, it's been driving me mad.... but I adjusted the two bump stop and achieved the same results.
Sutton Coldfield, West Mids
Xantia V6 Exclusive (2000
Xantia 1.9TD SX (2000)
Previously owned
Xantia V6 Exclusive (97)
XM V6 Exclusive (95)
AX 1.4
