VIN Decode
Relay exmod
Re: VIN Decode
Unread post by Relay exmod »
Trying to find out my engine number via vin as looks to have corroded away and need to register with dvla as was ex mod vehicle so no registration was issued
x 5679
Re: VIN Decode
Post your VIN, which will be obfuscated except to forum staff and we may be able to help.
Relay exmod
Re: VIN Decode
Relay exmod
Re: VIN Decode
Taken bracket down from near stater motor completely corroded due to engine dry and no paint applied to block like they used to
x 1083
Re: VIN Decode
Unread post by Rp0thejester »
'Obfuscated' what a horrible ' I'm better than you' word! This should be banned on this site and speak in laymen's terms
Relay exmod
Re: VIN Decode
Nightmare when even citroen won't help retrieve the data held because your not buying a brand new vehicle off them
x 1083
Re: VIN Decode
What are characters 4 to 9 on the VIN? That should give you engine
x 1481
Re: VIN Decode
Unread post by xantia_v6 »
Rp0thejester wrote: 11 Aug 2025, 20:24 What are characters 4 to 9 on the VIN? That should give you engine
C2MFC
x 1083
Re: VIN Decode
:rofl2: I'm not forum staff
PaulC5
x 714
Re: VIN Decode
Unread post by PaulC5 »
The letters in the vin will only give the engine type and not its serial number so the full vin needs to be used to look up the car characteristics which includes the engine serial number which I think Relay exmod wants. To post the vin or part of it without being hidden, it can be done by putting spaces between each letter and number.
Relay exmod
Re: VIN Decode
Tryed a couple of the payed hpi reports but no luck only give you the engine type even the like of car vertical don't have much regarding this
x 1083
Re: VIN Decode
If you can find the engine type from the VIN it would narrow it down considerably, as engines can put the engine plate on different areas of the block
x 5679
Re: VIN Decode
Rp0thejester wrote: 11 Aug 2025, 20:33 :rofl2: I'm not forum staff
C2MFC
Which looks odd to me.
x 1083
Re: VIN Decode
Off the top of my head I would say Citroen series 2 Multi people carrier....
Relay exmod
Re: VIN Decode
Dw10fu engine type 2.0 bluhdi
