VIN Decode
MGVDP
VIN Decode
Unread post by MGVDP »
Is there a possibility to obtain a build sheet of a new 3008 GT Hybrid from a VIN. The car is presently unregistered. I'm in the process of buying this car.
I look forward to a response :)
x 6954
Re: VIN Decode
We can help if you need an original genuine part number, part diagram or vehicle factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 3 years (pending continued service availability), so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
MGVDP
Re: VIN Decode
I have now upgraded the membership. Please find the VIN I'd like to see decoded or get the build sheet for
VR3**************[VIN obfuscated, can be read by forum staff]
x 6954
Re: VIN Decode
No problem, here you go:
Vehicle Characteristics
Vehicle family3008 (P64)
AS/RP N°17193 89 3 0351
Engine serial number10 XRAB 0015069
BERe2*2018/858*00064*01
P4AHOM-000667
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPEPEUGEOT
VEHICLE FAMILY3008 (P64)
SILHOUETTE5-DOOR CROSS OVER
TRIM LEVELUPPER MEDIUM
ENGINEEB2LTDH2 UE64 1.2 L PETROL
TRANSMISSION4X2 CONTROLLED TRANSMISSION
PAINT TYPEPAINTED METALLIC EXT TRIM TYPE
BODY COLOUROBSESSION BLUE PAINT
INTERIOR TRIM TYPENAPPA LEATHER "4H"
UPHOLSTERY COLOUR"FX"
GEARBOX (CHARACTERISTICS)EDCT GEARBOX
DEFINITION TO FOLLOWINITIALE RANGE
ENGINE (TYPE)EB TYPE ENGINE
ROOF (EXT. ASPECT)BLACK PEARL ROOF
PRE-EQUIPMENT FOR CONVERSIONWITHOUT PRE-EQUIPMENT FOR CONVERSION
BADGEGT
STEERINGVARIABLE POWER STEERING
Fuel Supply-Engine
FAN1-SPEED FAN 170W VARIABLE DYNAMIC AIR SHUTTER
DRIVE TRAINMHEV DRIVE TRAIN
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITHOUT STOP AND START
DRIVE BATTERYWITHOUT TRACTION BATTERY
FUEL SUPPLYDIRECT EXCHANGER TURBO INJECTION
FUEL FILLER CAPWITHOUT FUEL FILLER CAP
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
FUELUNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE)EURO 6.4 ENGINE EMISSION CONTROL
FUEL PIPE FIXINGSSTANDARD FUEL PIPE FIXING
SPEED SENSOR SIGNALFRONT WHEEL SENSOR NON-SIGN RR SIGNED
CAPACITY1200 CM3
CATALYTIC CONVERTERNOT AFFECTED
FUEL TANKFUEL TANK WITHOUT LOCATING TAB
FUEL TANK INSULATIONWITHOUT FUEL TANK INSULATION
COOLING MOTORRADIATOR 28DM2 - THICKNESS 21 BRAZED ALU
CRANKCASE GAS CIRCUIT HEATINGWITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE)ENGINE POWER 100 KW - 230 NM
EOBD SELF-DIAGNOSIS SYSTEMWITH "OBD" AUTO-DIAGNOSTICS
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.4 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
Gearbox Transmission
GEARBOX TYPEEDCT TYPE GEARBOX 6 SPEED
FINAL DRIVE RATIOTORQUE RATIO 18-17 X 76
WHEEL STYLEALU WHEEL DESIGN02 19 INCH
CLUTCHWITHOUT CLUTCH
SEAL, WHEEL ENDNOT AFFECTED
SEAL, DIFFERENTIAL ENDNOT AFFECTED
RIM/TYRE SIZE19 INCH TYRE FIT
TYRE (SIZE, TYPE)TYRE 225/55 R19 103V -REINFORCED
DRIVING WHEELS2 DRIVEN WHEELS
WHEELS FITTEDWHEEL 7.5J19ET50
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATORINDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION
Suspension-Steering-Brakes
BRAKE ASSOCIATED VARIANTESP BOSCH 9.3 HSM
STEERING (OPERATION)HIGH POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE)PEDAL ALUMINIUM
BRAKING ASSISTANCE IN REVERSE GEARCOLLISION WARNING - RCTA
ABSWITH ABS BRAKES
REAR ANTI-ROLL BARRR ANTI-ROLL BAR STIFFNESS 39000 NM/RAD
ANTI-THEFT DEVICEANTI-THEFT USING AUTOMATIC GEARBOX LOCKING
STEERING COLUMNMANUALLY ADJUSTED STEERING COLUMN
FRONT ANTI-ROLL BARFR ANTI-ROLL BAR STIFFNESS 37500 NM/RAD
TRACTION CONTROLANTISLIPPING
BRAKE TYPEVENTILATED FRONT DISCS/REAR DISCS
SUSPENSIONNORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE)METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
Body Fittings
TOWBARTRAILER PRE-EQUIPMENT
HORNSHORNS-HARMONY
PAYLOADNORMAL PAYLOAD
DECORATION (PAINTED)GLOSS BLACK DECOR
SIDE MOULDINGS (TYPE)LATERAL PROTECTOR MASS TINTED
SIDE MOULDINGS (DIMENSION)WITHOUT SIDE PROTECTORS + PEUGEOT SIDE SILL
WHEEL EMBELLISHER (STYLE)WITHOUT WHEEL TRIM
EXHAUST TAILPIPEEXHAUST OUTLET REAR LH
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
WASHER JETSTANDARD SCREEN WASH JET
EXT. REARVIEW MIRROR COMP. FUNCTIONDRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY
WINDSCREEN GLASS (TYPE)STANDARD WINDSCREEN GLASS
WINDSCREEN WIPERFRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPERWITHOUT REAR WIPER + CAMERA WASHING
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
ROOF GLASSWITH SLIDING TILTING ROOF WINDOW ONE-TOUCH CONTROL ANTI-PINCH
SIDE LOAD DOORWITHOUT SLIDING SIDE DOOR
BUMPERBUMPERS FR/RR DESIGN 03
NUMBER PLATEFRONT IMPLANTATION EUROPE LICENCE PLATE
FRONT FOGLAMPNO FRONT FOG LIGHTS
PANORAMIC VISUAL AIDDIGITAL PANORAMIC VISUAL ASSISTANCE
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE)HT EXT RRVW MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE)OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
SPARE WHEELWITHOUT SPARE WHEEL
EXTERIOR ACCESSORIESBODY COLOUR EXTERIOR HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)CURVED EXTERIOR MIRROR GLASS
GLASS (APPEARANCE)TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE)ACOUSTIC WINDSCREEN
Interior Fittings
SEATING ASSOCIATED VARIANTVARIANT ASSOCIATED WITH HIGH SEAT POSITION
DRIVER’S KNEE AIRBAGWITHOUT KNEE AIRBAG
SUPPLEMENTARY HEATERWITHOUT ADDITIONAL HEATING
AUDIO PACK AUXILIARY SOCKETAUDIO PACK AUXILIARY SOCKET 1 USB TYPE C
TELEMATIC UNITINDEPENDENT TELEMATIC UNIT
ANTI-THEFT ALARMVOLUME + PERIMETER + LIFT
FRONT HEAD RESTRAINTFRONT HEAD RESTRAINT CONTROL 2-WAY INTEGRATED COND+PASS
REAR SEATMONOCHROME REAR SEAT FX+FOLDING 40/20/40 SEAT BACK
SUPPLEMENTARY SEATWITHOUT ADDITIONAL SEAT
BLIND SPOT DETECTIONBLIND SPOT MONITORING + LANE CHANGE ASSIST
REAR SEAT ARMRESTWITH REAR SEAT ARMREST
CABIN SEATWITHOUT CAB SEAT
INT. LOAD RETENTION4 LASHING RINGS
LUGGAGE COVER (TYPE)TRAY TYPE LUGGAGE COVER
RADIO TELEPHONE2 SMARTPHONES
LUGGAGE COVERSHELF
REAR SEATBELTPYR SIDE REEL + 3 POINT CENTR + UNBUCKLED WARNING
FRONT SEATBELTPYROTECHNIC SEAT BELT WITH ALARM
CLIMATE (AMBIENT TEMP)HOT OR WIDER TEMPERATE COUNTRY
AIR CONDITIONINGAIR CON WITH AERO + RECIRC + ADDITIONAL OUTLET
CHILD LOCKMANUAL REAR CHILD LOCK
SPEED GRADUATIONSSPEED GRADUATION IN MPH
GEAR SELECTORGEAR LEVER ON THE DASHBOARD+SS WHEEL
GRAB HANDLESFRONT+REAR HANDLES+HOOKS+RETRACTABLE
CONSOLELONG CONSOLE + REAR AIR DUCT
SUPPLEMENTARY SEAT ADJUSTMENTWITHOUT ADD SEAT ADJUSTMENT
DRIVING POSITIONRIGHT HAND DRIVE
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
MIRROR LINKWITH MIRROR LINK
LOAD SPACE LIGHTINGGLOVEBOX+LED FRONT CONSOLE
BOOT AND LOAD SPACE LIGHTINGWITHOUT BOOT LIGHT
DASHBOARD EQUIPMENTDASHBOARD SLUSH+FABRIC ALU+CAST
INT. TRIM AND EQUIPMENT VARIATIONSTANDARD INTERIOR EQUIPMENT DRESSING
WORK TABLEWITHOUT WORK TABLE
INSTRUMENT PANEL (CHARACTERISTICS)PANORAMIC INSTRUMENT PANEL SCREEN 21 INCH HD
CHILD SEAT ANCHORING POINTSCHILDSEAT ANCHORS FR NO ISO NO TT/RR 2ISO+2TT
LOUDSPEAKER5 FR SPEAKERS (2 TW + 2 FR + 1 CENT)
PROTECTIVE COVERWITHOUT PROTECTIVE BATTERY COVER
RADIO CONTROLSSTEERING WHEEL AUDIO SYSTEM CONTROL
ADDITIONAL BLOWERWITHOUT ADDITIONAL PULSE
POLLEN FILTERALLERGEN FILTER
LANE KEEPING MANAGEMENT ASSISTANCELPA + SEMI-AUTO LANE CHANGE (SALC)
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT+ELECTRIC FRONT SEAT CUSHION ANGLE
DRIVER SEAT CONTROLDRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT
FRONT PASSENGER SEAT CONTROLPASSENGER’S FR ELEC SEAT CTRL + CUSHION FRONT ADJ
DRIVER SEAT ADJUSTMENTDRIVER’S SEAT ELECT LUMBAR SUPPORT+PNEUMATIC SIDE ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENTFRONT PASSENGER’S SEAT WITH ELECT LUMBAR SUPPORT+PNEUMATIC SIDE ADJUSTMENT
FRONT PASSENGER SEAT FOLDINGW/O FOLDING PASS FRONT SEATING
INT. UPHOLSTERY ELEMENTSMISTRAL INTERIOR ROOF TRIM
FRONT SEAT ARMRESTFRONT CENTRAL ARMREST
COMPACT DISCWITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEMCONNECTABLE NAVIGATION SYSTEM
HEADLAMP BULBSLED BULB
FRONT WINDOW LIFTDRIVER+PASSENGER FRONT ELECTRIC WINDOW
REAR WINDOW LIFT2 ELEC WINDOW FR
TRAFFIC INFORMATION READERLKA STRUCTURAL EDGE
DISPLAYPANORAMIC MONITOR DISPLAY 21 INCH HD
COURTESY MIRRORDRIVER’S AND PASSENGER’S COVERED MIRROR WITH LED
FOOTRESTDRIVER’S FOOTREST
CUSHION PADDINGPADDING WITH PASSENGER DETECTION PAD
HEATING ELEMENTDRIVER’S SEAT+PASSENGER ROW1&2 + VENTILATED ROW1
FRONT LATERAL AIRBAGFR CHEST/PELVIS SIDE AIRBAG+FR/RR CURTAIN
FOOTWELL LIGHTINGFOOTWELL LIGHTING WITH LED
REAR PASSENGER PROTECTIONW/O RR PASSENGER PROTECTION
PASSENGER AIRBAGWITH AIRBAG ON PASSENGER SIDE
ADDITIONAL AIR CONDITIONINGWITHOUT ADDITIONAL AIR CONDITIONING
ON-BOARD COMPUTERCOMPUTER
EQUIPMENT PACKW/O EQUIPMENT PACK
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE)CHROME FINISH INSIDE DOOR HANDLE
HEADLAMP HEIGHT ADJUSTERAUTOMATIC HEADLAMP ADJUSTMENT
FRONT SUN VISORDRIVER’S+PASSENGER’S SIDE (WITH + W/O INSCRIPTION)
WIFIWITHOUT WIFI
RADIO RECEIVERANALOGUE + DAB RADIO RECEIVER
REFRIGERATIONRFTA REFRI - REFRI AUTO TEMP CONTROL
CRUISE CONTROLACC3 DECEL0 + ACCEL0
DRIVER’S SEAT HEIGHT CONTROLELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRRORFRAMELESS INTERIOR ELECTROCHROMATIC MIRROR
AIR CON./TEMPERATURE REGULATIONWITH DUAL ZONE AIR CON/TEMP CONTROL
STORAGE (OTHERS)PLAIN STORAGE POCKET
CARPET COVERUPPER GT
DRIVER AIRBAGDRIVERS AIR BAG
LOAD SPACE STORAGERETRACTABLE FLOOR STORAGE COMPARTMENT
REAR SEAT PADDINGWITHOUT RR PASSENGER DETECTION
TUNER RADIODUAL RADIO TUNER
OBSTACLE DETECTION SYSTEMFRONT/REAR/SIDE RADAR OBSTACLE DETECTOR + TRAJECTORY
LATERAL BLINDSWITHOUT SIDE BLINDS
RADIO FREQUENCYRADIO FREQUENCY AMT6_FMT4-50-DIAFTAPSTMC_DABT1
STEERING WHEELPERF FULL GRAIN LEATHER STEERING WHEEL GT INSERT
Electrical
LIGHTING OF LAMPSAUTO LIGHTING + ADAPTIVE SWITCHING
ALTERNATORWITHOUT ALTERNATOR
HORNSHORNS-HARMONY
BATTERYBATTERY L3 720 LDC**************[VIN obfuscated, can be read by forum staff]
STARTER MOTORWITHOUT STARTER MOTOR
SPECIAL LIGHTINGFRONT DAY RUNNING LIGHT (DRL)
CEN. LOCKING REM CONTROL FREQUENCY433.92 MHZ SUPER HETERODYNE
ELECTRICAL EQUIPMENT (SUPPLY)STANDARD PROVISION ELECTRICAL EQUIPMENT
BATTERY CHARGERWITHOUT BATTERY SLOW CHARGE
MULTIPLEXINGMULTIPLEXING NEA R1.1
ELECTRIC VEHICLE CHARGING PLUGWITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENTWITH BOSCH GENERATION 4 BATTERY CHARGE MEASUREMENT
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
MODIF. DURING MODEL YEARWITHOUT MINOR MODIFICATIONS
CONDENSER (SPECIFICATIONS)CONDENSER 23.5 DM2 THICKNESS 12 UPPER CONNECTOR
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT LABEL
AIR CONDITIONING PIPESWITHOUT AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKETTRIPLE ACCESSORIES SOCKET
TRAFFIC SIDEDRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTSUPPER REINFORCED SIDE IMPACT PROTECTORS
SET OF KEYSSET OF BADGE KEYS + BACK-UP KEY
REFRIGERANTAIRCON FLUID 1234 YF
EMERGENCY EQUIPMENTPUNCTURE REPAIR KIT
SURFACE CONDITIONSGOOD TERRAIN
SPEED MONITORINGWITHOUT SPEED CHECK
MGVDP
Re: VIN Decode
Thank you, Marc, fabulous service, although I am a bit confused, there are a lot of "withouts" :) and more importantly, I had expected a build date. Furthermore, this sheet doesn't show the options (sunroof and focal for example in the sensation pack, or 360 vision in the drive assist pack).
Am I expecting too much from a VIN decode, or did I ask for the wrong information ?
PaulC5
x 662
Re: VIN Decode
Unread post by PaulC5 »
In the build sheet the RPO 17193 gives a build date of 5th December 2023 from this calculator https://bartebben.nl/map/peugeot-citroe ... ummer.html
I think you need to look at the door pillar sticker to confirm this RPO number since if correct the car is well over 1 year old despite it not yet being registered. There was a topic not too long ago about something similar and the person rejected the car after finding out it was older than the car he was replacing. If the date is correct and you still want to buy the car, you should not be paying the current price of a new one. I do not know what car depreciation is over the first year but it could easily be 20 to 30%.
MGVDP
Re: VIN Decode
I couldn't have asked to have been better informed. I cannot thank you enough! As I also speak Dutch, I also understood the website in the link's explanation. There's no doubt, everything makes sense now, only the name difference "ORGA" and "AS/RP" don't perfectly align, is this a language issue? I also speak French, what does AS/RP stand for or are these English acronyms.
You're an absolute star, Paul :)
PaulC5
x 662
Re: VIN Decode
Just looked at the linked site again and top right I found I could click on the flag and find a union jack so in English. On it it gives RP as replacement part.
x 6954
Re: VIN Decode
Yes the RPO is the build date (17193) and is as said 5th December 2023.
The build sheet does not specify the features, only the equipment of which the features may be a part.
So you would need to check the correct brochure (based on the brochure publication date and the build date of the vehicle) to check what the trim level specifies and then very importantly if any option packs were ordered - or more importantly not ordered. There's been many cases here where people have been caught out thinking that a top trim level contains everything - it does not.
There are some features and equipment that are only part of additional 'Option Packs', so there's no way to know this from the Build sheet, but only through checking the vehicle itself.
Sometimes you will see a specific type of ESP system often referred to as on the build sheet as ORM adaptive ESP system that is commercially referred to as 'Grip Control' as one example.
Another is the type of cruise control - it it is a radar type then one can assume it has active lane keeping Assist - but again these features are still option dependent as some are autonomous and some are semi-autonomous.
Parking Assistance is another feature - as that may indicate if there is a rear camera, a 'Panoramic Camera' system or neither.
MGVDP
Re: VIN Decode
I cannot thank you enough for all this extremely valuable information. I will handle the situation appropriately, and then, you can rely on another fully deserved donation :) together with a full explanation of what happened.
PaulC5
x 662
Re: VIN Decode
Something else you have to watch these days, if the list price when new is £40k or more the road tax is about £600 a year for 5 years. This will likely go up each year as the government want more. I do not know if this uses the list price when the car was built or when it was registered.
MGVDP
Re: VIN Decode
Thank you for all the valuable info on here. Could I have another build sheet for: VR3**************[VIN obfuscated, can be read by forum staff]
Thank you in advance
x 6954
Re: VIN Decode
Here you go and this build date is: 13th February 2025
AS/RP N°17629 89 3 0370
Engine serial number10 ZA04 0118080
BERg11*2018/858*00524*02
P4AHOM-000667
General Information
INTERIOR TRIM TYPENEW UZIRIS FABRIC + TEP "T5"
OTHER BADGEHYBRID ENGINE ADDITIONAL BADGE
BADGEGT
Fuel Supply-Engine
CAPACITY1200 CM3
SPECIAL POWER TRAIN SOUNDWITHOUT POWER TRAIN ACOUSTICS
FAN1x1-SPEED 170 W AERO FAN DYNAMIC SHUTTER W/O RELAY
ABSWITH ABS BRAKES
Body Fittings
HORNSHORNS-HARMONY
EXT. LOAD RETENTION RING (ATTACHMENT)BOAT EXT LASHING RING
ROOF GLASSWITHOUT ROOF WINDOW
SUN ROOFPULSE ELECTRIC SUNROOF
Interior Fittings
LUGGAGE COVERSHELF
SPEED GRADUATIONSSPEED GRADUATION IN MILES + KILOMETRES
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT
DRIVER SEAT CONTROLMANUAL DRIVER’S SEAT CONTROL
FRONT PASSENGER SEAT CONTROLMANUAL FRONT PASSENGER SEAT CONTROL
DRIVER SEAT ADJUSTMENTDRIVER’S SEAT BACK WITH ANGLE ADJUSTMENT AND LUMBAR SUPPORT
FRONT PASSENGER SEAT ADJUSTMENTWITHOUT FRONT PASSENGER’S SEAT ADJUSTMENT
HEATING ELEMENTDRIVER + R1 PASSENGER HEATED SEAT
WIFIWITHOUT WIFI
DRIVER’S SEAT HEIGHT CONTROLDRIVER’S HEIGHT ADJUSTER HEIGHT ADJUSTMENT
Electrical
HORNSHORNS-HARMONY
BATTERY (FITTING)STANDARD
Miscellaneous
LABELGREAT BRITAIN
RADIO HEADPHONE SOCKETDOUBLE ACCESSORY SOCKET
EMERGENCY EQUIPMENTW/O HELP EQUIPMENT
MGVDP
Re: VIN Decode
Thank you, I'm impressed with this forum, please send me a link to arrange another donation.
x 6954
Re: VIN Decode
No need, but thanks anyway. You were lucky I could get that last request for you, as we are unable to provide further parts / VIN sheet data at present until we get the Forum's account consolidated over to the new Stellantis system.
Details here:
viewtopic.php?t=69962
