Hello,
Can anyone please advise where the fuel and pollen filters are on a 2022 Citroen C4 1.5 BlueHdi 130? Thanks
C4 Fuel filter and pollen filter locations
Tarrymittens
PaulC5
- x 680
Re: C4 Fuel filter and pollen filter locations
Off hand I do not know where these are located. If you are thinking of doing your own servicing rather than using the dealer, beware that the 1.5 hdi camshaft chain can fail and if not dealer serviced you may not benefit from any goodwill from Citroen to pay for the engine repairs. This goodwill seems to extend for a few years after the 3 year warranty expires.
Tarrymittens
My understanding is that engines after 2020 are fitted with the upgraded 8mm chain
- x 1486
The date change to 8mm is a bit variable. If you post the VIN we can check, and advise on location of the filters.
- x 6957
No, that's incorrect. Only models from late 2023 have the 8mm chain fitted, but as said VIN will confirm.Tarrymittens wrote: 05 Mar 2025, 11:02 My understanding is that engines after 2020 are fitted with the upgraded 8mm chain
As for the filters, they are located inside the heater unit. To get to this you will need to remove the lower driver's side trim and side panel of the central console at the driver's footwell: Once you have the area visible you are looking for this panel that locks them in - unscrew it: Then pull both filters out to the right (there are 2). The pull then down:
Tarrymittens
VIN No. VR7**************[VIN obfuscated, can be read by forum staff]
Tarrymittens
Hi Marc,
Thanks for the information. Any information on location of fuel filter?
- x 6957
The filter is contained within the housing in the engine bay similar to the one shown in this post:
viewtopic.php?t=85420
