Resetting automatic gearbox oil counter kinda failed?
woozie
Re: Resetting automatic gearbox oil counter kinda failed?
Unread post by woozie »
LedZep wrote: 17 Feb 2025, 16:38
woozie wrote: 17 Feb 2025, 16:13 Key in the service reader. Diagbox 9.128 The only think was the temperature - the oil was cold. During changes manual says 60-80 from what I remember.
To change the oil of the gearbox, this must be warm for sure around 60+. Because there is some time that i changed it, i can't remember exactly all the requirements.
O.K. Then your only choice is to try out another version of Diagbox like i did. This solved my problem. I think that with 9.129 i did the reset. With 9.91 ver. had problems too. But 9.168 ver. is working best of all at least for my car and year. There are some links..in your own risk. I didn't had problems although.
Could you pinpoint the one you used? Is there a virtual box one. There is no hassle with installing it. 😀
LedZep
x 30
Unread post by LedZep »
You have PM.
