Hello i am in the procees of fitting a new crankshaft to the above engine 1.6 HDI BHZ . vin VF3**************[VIN obfuscated, can be read by forum staff]
My question is what is the torque spec for the main bearings and the big ends , do you have to renew the bolts as i am getting conficting info .
If the bolts require replacment where can i buy the other than a main dealer . Thanks Phil .
Help needed with BHZ Engine
phil227
Re: Help needed with BHZ Engine
Hello yet another request whree can i get the caps that cover the mainbearing bolts ( flywheel end knock on metal cap over bolts x2 part number if possible ) Many thanks yet again Phil .
- x 6957
Phil
Can't help with the torques, but let me know what part numbers you need for any items on the diagram: once you have these you can order them from your dealer or elsewhere if available.
Steve Walsh
- x 515
Not wanting to stand on Marc's toes,
The metal caps are on the diagram for engine block,
I have a copy of Autodata up to 2014, I f you give me year and vehicle model I might be able to get you torque specs
Hope this helps
Steve
Hope this helps
Steve
- x 6957
Thanks Steve - Engine Block Diagram too:
phil227
Thanks to all . Steve have you a part number for items 2 and 8 in the last diagramme . Thanks Phil .
Steve Walsh
- x 515
Hi Phil
Numbers I have are not guaranteed to be up to date, The Mods / admin will have access to latest data.
But
Number 2. 0132 54
Number 8.0167 82
But
Number 2. 0132 54
Number 8.0167 82
- x 6957
So that part number for (2) is out of date Steve.
(2) MUL Hex Head Machine Screw, part: 9813900780, £3.19
(8) Well Cap on Cylinder Block, part: 016782, £2.46
phil227
Hello the story goes on . i am now after a con rod as the bearings have spun and damaged the inner face .
So my question is are the rods all the same i have a BHZ engine ( Vin supplied in this earlier post ) can i have a part numer if possible are all the (B) engines the same internally ?
Thanks as always Phil : north wales .
