Ds3 power steering ABS errors
tobik
Unread post by tobik »
Hi bought this DS3 with some faults on dash thinking it’s going to be asy fix but it doesn’t go well.
I have power steering message on display along with abs faulty and abs/asr faulty.
Changed battery and alternator still the same. New alternator only outputs 13.5v
Local garage insist it needs new power steering ECU.
Any help would be greatly appreciated.
It’s DS3 2014 1.2 vti 82
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Is this one definitely non start stop?
x 1454
Re: Ds3 power steering ABS errors
Unread post by xantia_v6 »
No comms with the steering ECU could be caused by no power to the ECU (fuse, wiring or BSM), or a fault on the communication bus (short or open circuit), or the ECU itself.
I would start by checking every fuse in the car, and/or check the voltages at the steering ECU.
tobik
How can I test the power going to steering ecu? It has ground wire and B+ thick red wire going directly in to the body of ECU which is part of steering rack.
x 6957
I can't really help with all those errors as you have comms errors on the CAN network, and also a positive feed failure on the MFD, which may indicate something with the charging circuit or positive feed that may also be affecting the Power Steering - as this is fed directly from the battery.
(11) Electric power steering motor.
(12) Supply connector (+ ignition on ): Multiplexing network (CANH/CANL).
(13) Supply connector (Permanent +).
(14) Body earth.
The steering assistance is obtained by the assistance electric motor (11) controlled by an ECU.
The current supplied to the assistance electric motor (11) depends on the following elements:
  • Vehicle speed
  • Torque applied to the steering wheel
The electric power steering ECU is incorporated in the steering mechanism.
The calibration of the ECU is adapted to the engines and the pneumatic systems fitted.
tobik
Thanks for the info.
I’ve done some testing on the wires going to power steering ECU I get ignition 12v on on wire and 2.5v on the other two.
Resistance between thick black and red wire shows 0L.
I think this means power steering motor is faulty?
After putting everything back together I got another fault U1118 🙄🫣
x 6957
These codes are missing the last 2 digits (probably a limitation of your diagnostic equipment), so I can't be specific, but U1118 refers to comms issues between the powers steering ECU and probably the engine ECU or BSI and the C1321 08 is Power steering communication not valid.
tobik
Can anyone check what is the correct part number for steering rack for my vehicle? Can not read from the label. VIN is in the first post.
tobik
Anyone?
x 6957
We can help if you need an original genuine part number, part diagram or vehicle factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 3 years (pending continued service availability), so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
tobik
Called main dealer and was told it is:
1627704280 for version with Steel Subframe
Cost only £2000. What a ripoff. 😳
x 6957
Bargain!
It's another £560 on top of that here:
https://peugeotcitroendsparts.com/produ ... 04280.html
