DS3 etense VIN issue
AnthonyDS
Unread post by AnthonyDS »
Hi,
I recently bought a DS3 etense and imported it to Australia. It turns out that I need to provide a VIN decode in order to get it recognised here and get registration. I’ve gotten most of the way but there appears to be an error with the check digit character assuming it is indeed position 9. When I run the VIN through a calculator it tells me the check digit is incorrect and should be X rather than Z.
It’d be great to know if I’m on the right track.
Info below
VR1**************[VIN obfuscated, can be read by forum staff]
??????1.????Position 1 – Country of Origin (V):
??????•?????V indicates the vehicle was manufactured in France.
??????2.????Positions 2-3 – Manufacturer (R1):
??????•?????R1 represents DS Automobiles, which is part of the PSA Group (now Stellantis).
??????3.????Position 4 – Vehicle Line (U):
??????•?????U corresponds to the DS 3 Crossback model line.
??????4.????Position 5 – Body Style (J):
??????•?????J signifies a 5-door hatchback body style.
??????5.????Position 6 – Engine Type (Z):
??????•?????Z denotes an Electric Motor, indicating the E-Tense variant.
??????6.????Position 7 – Safety Equipment (K):
??????•?????K indicates the vehicle is equipped with front and side airbags.
??????7.????Position 8 – Transmission (X):
??????•?????X represents an Automatic Transmission.
??????8.????Position 9 – Check Digit (Z):
??????•?????Z is the check digit used for validating the VIN.
??????9.????Position 10 – Model Year (L):
??????•?????L corresponds to the model year 2020.
??????10.???Position 11 – Assembly Plant (W):
??????•?????W stands for the Poissy Plant in France, where the vehicle was assembled.
??????11.???Positions 12-17 – Sequential Production Number (024330):
??????•?????024330 is the vehicle’s unique production sequence number.
x 6950
Re: DS3 etense VIN issue
AnthonyDS
Thanks Marc,
From what I can see in your previous post with the VIN decode, there isn’t a check digit at all! Does that mean that the DS VINs aren’t compliant with ISO3779?
