Vin number lookup
Expertamateur
- x 27
Vin number lookup
I am about to purchase a Peugeot 307cc and would like to check it has a genuine VIN number. I have tried a few VIN decoder sites online but they give incomplete or confusing information. Any ideas what to do?
Absolutely hate modern cars and being ripped off by garages that play parts roulette.
OnlinePaulC5
- x 675
Re: Vin number lookup
You could put the VIN on here and hopefully admin will look it up for you.
- x 6956
We can help if you need an original genuine part number, part diagram or vehicle factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 3 years, so excellent value.Expertamateur wrote: 21 Nov 2024, 15:51 I am about to purchase a Peugeot 307cc and would like to check it has a genuine VIN number. I have tried a few VIN decoder sites online but they give incomplete or confusing information. Any ideas what to do?
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
| A response to your question by a Forum Admin requiring parts or specific vehicle information requires you to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum. |
Expertamateur
- x 27
OK Paul, here goes.PaulC5 wrote: 21 Nov 2024, 21:34 You could put the VIN on here and hopefully admin will look it up for you.
- x 6956
I'm not sure what you mean by a 'genuine' VIN - that doesn't really make any sense - it will have a VIN that corresponds to the vehicle or it won't, but in either case here's your build sheet:
307 RESTYLING COUPE CABRIOLET - 2 DOOR 2.0 i 16v 143 (EW10A) Manual gearbox 5
| Vehicle Characteristics | |
| Vehicle family | 307 RESTYLING |
| AS/RP N° | 10621 89 1 0847 |
| Warranty Start Date | 30/03/2006 |
| Engine serial number | 10 LH4P 1404260 |
| BER | e2*2001/116*0313*01 |
| General Information | |
| PRODUCT TYPE | PASSENGER CAR |
| COMMERCIAL MARQUE/COMPONENT TYPE | PEUGEOT |
| VEHICLE FAMILY | 307 RESTYLING |
| SILHOUETTE | COUPE CABRIOLET - 2 DOOR |
| TRIM LEVEL | UPPER HIGH |
| ENGINE | EW10A INJECTION |
| TRANSMISSION | BVM5 |
| PAINT TYPE | METALLIC PAINTWORK |
| BODY COLOUR | EZR - PAINT ALUMINIUM GREY |
| INTERIOR TRIM TYPE | BRAID ANDORRA GLOSS + EFKA "RC" |
| UPHOLSTERY COLOUR | "FX" |
| GEARBOX (CHARACTERISTICS) | GEARBOX BE4 S |
| ENGINE (TYPE) | EW/DW |
| OTHER BADGE, " MISC. " | WITHOUT FULLER BADGE |
| BADGE | CC |
| STEERING | VARIABLE POWER STEERING |
| SPEEDOMETER DRIVE | CT 22 X NO |
| Fuel Supply-Engine | |
| DIESEL FILTER WATER DETECTOR | WITHOUT DIESEL FILTER WATER DETECTOR |
| CYLINDER BLOCK (MATERIAL) | CRANKCASE ALUMINIUM |
| FUEL | UNLEADED PETROL 95 QUALITY A/B/E/E+ |
| EMISSIONS STANDARD (ENGINE) | EURO 4 ENGINE EMISSION CONTROL |
| CATALYTIC CONVERTER | 3-COMPONENT RHODIUM+PLATINUM FILTER CATALYSER |
| OIL COOLER | MNTG WATER/OIL EXCHANGER ON ENGINE |
| CRANKCASE GAS CIRCUIT HEATING | W/O HEATER CASING GAS CIRCUIT |
| EOBD SELF-DIAGNOSIS SYSTEM | "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER |
| VEHICLE TECHNICAL DEPOLLUTION | L5 VEHICLE TECHNICAL DEPOLLUTION |
| PARTICLE FILTER | WITHOUT PARTICLE FILTER |
| FAN | 2 FANS , 2 RATES , IMPROVED 130WAERO |
| FUEL VAPOUR RETRIEVAL | CONTROLLED PETROL VAPOUR RECUPERATION |
| INJECTION ASSOCIATED VARIANT | MOUNTING MAGNETI MARELLI |
| TANK FILTER | RESERVOIR FILTER INTERIOR |
| STOP AND START | WITHOUT STOP AND START |
| Gearbox Transmission | |
| FINAL DRIVE RATIO | REAR AXLE HYPOID GEARSET 19 X 77 |
| WHEEL STYLE | EQUINOX 16 INCH WHEEL |
| CLUTCH | HYDRAULIC CLUTCH |
| GEARBOX TYPE (TYPE APPROVAL) | GEARBOX BE4/5 S TYPE |
| DIFFERENTIAL (GEARBOX) | DIFFERENTIAL 84 |
| RIM/TYRE SIZE | 16 INCH TYRE FITMENT |
| TYRE (SIZE, TYPE) | TYRE 205/55 R16 91V NON REINFORCED |
| WHEELS FITTED | 6,5" RIM ROAD WHEELS |
| WHEEL (TYPE) | ALLOY WHEELS |
| INFLATION PRESSURE LOSS INDICATOR | WITHOUT TYRE DEFLATION INDICATOR |
| GEARBOX TYPE | GEARBOX BE4R |
| Suspension-Steering-Brakes | |
| REAR ANTI-ROLL BAR | REAR ANTI ROLL BAR DIAM 27 |
| FRONT ANTI-ROLL BAR | FRONT ANTI-ROLL BAR DIAM 22 |
| POWER STEERING FLUID COOLING SYSTEM | WITHOUT POWER STEERING OIL COOLING |
| SUSPENSION | NORMAL SUSPENSION |
| DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
| BRAKE ASSOCIATED VARIANT | ESP BOSCH 8 0 |
| STEERING (OPERATION) | ASSISTED ELECTROHYDRAULIC STEERING |
| PEDAL BRACKET (TYPE) | PEDAL STANDARD |
| Body Fittings | |
| TOWBAR | WITHOUT TOWBAR |
| HORNS | HORNS-HARMONY |
| AERIAL | INTEGRAL AERIAL |
| SIDE MOULDINGS (TYPE) | BODY COLOUR LATERAL PROTECTORS |
| SIDE MOULDINGS (DIMENSION) | LATERAL PROTECTORS + SIDE SILL |
| WHEEL EMBELLISHER (STYLE) | APOLLO TYPE |
| REVERSING LAMPS | WITH 1 REVERSING LAMP |
| ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
| EXT. REARVIEW MIRROR COMP. FUNCTION | EXT MIRROR ELECTRIC-FOLD BACK |
| EXHAUST TAILPIPE TRIM | WITH EXHAUST OUTLET EMBELLISHER |
| ENGINE BAY SOUNDPROOFING | BONNET SOUNDPROOFING |
| WINDSCREEN WIPER | FRONT WIPER BLADE W/O RAIN SENSOR |
| REAR SCREEN WIPER | W/O REAR SCREEN WASH WIPE |
| HEADLAMP WIPER | W/O HEADLAMP WIPER |
| FRONT PANEL BLANK | WITHOUT FRONT BUMPER PLUG |
| ROOF GLASS | WITHOUT ROOF WINDOW |
| BUMPER | BODY COLOUR FRONT/REAR SPORT BUMPER WITH RUSH |
| MUDFLAP | WITHOUT REAR MUDGUARD |
| FRONT FOGLAMP | FRONT FOG LIGHTS |
| EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) | DRIVER’S DOOR MIRROR ELECTRIC CONTROL |
| EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) | PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL |
| SPARE WHEEL | REDUCED STEEL WHEEL + NON STD TYRE |
| EXTERIOR ACCESSORIES | BODY COLOURED EXT HANDLE+FLAP TRIM+EXT MIRROR |
| REAR SCREEN WASH | W/O REAR SCREEN WASH |
| SUN ROOF | SUNROOF CONCEALABLE |
| BUMPER TRIM | BODY COLOUR BUMPER STRIP |
| GLASS (APPEARANCE) | TINTED + DARK-TINTED RR WINDOW GLASS |
| REAR QUARTER WINDOW (TYPE) | SLIDING REAR QUARTER GLASS |
| WINDOW (TYPE) | ACOUSTIC LAMINATED W/SCRREN+TOUGHENED SIDE RR |
| RADIO-INFORMATION-COMMUNICATION PACK | RD4, NO NAV, LEV C DISP, NO AMPLI-EQUALIZER |
| Interior Fittings | |
| ANTI-THEFT ALARM | WITH THEFT PROTECTION ALARM |
| REAR HEAD RESTRAINT | REAR HEADREST ADJUSTABLE |
| FRONT HEAD RESTRAINT | JOINTED FRONT HEADREST |
| REAR SEAT | RR BENCH SEAT 1 CUSHION SEP BACKREST NON FOLDING |
| SUPPLEMENTARY SEAT | WITHOUT SUPPLEMENTARY SEAT POSITN |
| REAR SEAT ARMREST | WITHOUT RR SEAT ARMREST |
| LOAD FLOOR MOULDING | WITHOUT LOAD FLOOR STRIP |
| LUGGAGE COVER | WITHOUT LUGGAGE COVER |
| REAR SEATBELT | REAR INERTIA-REEL SAFETY BELT |
| FRONT SEATBELT | PYROTECHNIC SEAT BELT WITH ALARM |
| CLIMATE (AMBIENT TEMP) | TEMPERATE COUNTRIES |
| SPEED GRADUATIONS | SPEED GRADUATION IN MPH |
| RADIO EQUIPMENT | FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER |
| DRIVING POSITION | RIGHT HAND DRIVE |
| ADDITIONAL HEATING | WITHOUT ADDITIONNAL HEATING |
| DASHBOARD EQUIPMENT | DASHBOARD STANDARD + FACADE GREY LION |
| INT. TRIM AND EQUIPMENT VARIATION | LEATHER ST WHL AND GAITER + ALU GEAR KNOB |
| UNDERSEAT STORAGE | WITHOUT UNDER SEAT STORAGE |
| INSTRUMENT PANEL (CHARACTERISTICS) | GRAD 250 KM/H 160 MPH WHITE BGROUND CHROME CIRCLE |
| LOUDSPEAKER | 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS |
| RADIO CONTROLS | REMOTE RADIO CONTROL WITHOUT CD FUNCTION |
| SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) | WITHOUT REAR BLIND |
| FRONT PASSENGER SEAT HEIGHT CONTROL | FRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT |
| DRIVER SEAT CONTROL | DRIVERS FRT SEAT MANUAL CNTROL |
| DRIVER’S SEAT FOLDING | WITH FOLD DRIV FRONT SEATING |
| FRONT PASSENGER SEAT FOLDING | WITH FOLD PASS FRONT SEATING |
| FRONT SEAT ARMREST | ASSEMBLY WITHOUT FRONT ELBOW REST |
| EXTERIOR TEMP. INDICATOR | EXT TEMP INDICATOR |
| COMPACT DISC | WITHOUT COMPACT DISC |
| STOWAGE BIN | WITHOUT SETTING BOX |
| SATELLITE NAVIGATION SYSTEM | WITHOUT NAVIGATION SYSTEM |
| HEADLAMP BULBS | HALOGEN BULB |
| REAR WINDOW LIFT | SEQENT CONTR RR WINDOW LIFTER |
| DRIVER’S WINDOW LIFT | SEQUENTIAL DRIVER’S ELECTRIC WINDOW |
| PASSENGER’S WINDOW LIFT | SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER |
| DISPLAY | DISPLAY (RADIO+CLOCK,T°,CD) |
| COURTESY MIRROR | DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT |
| FOOTREST | WITHOUT FOOTREST |
| OIL GAUGE | OIL TEMP + LEVEL INDICATOR |
| FITTING REAR HEAD RESTRAINT | MOUNT 2 REAR HEAD-REST |
| HEATING ELEMENT | NON HEATED SEAT |
| FRONT LATERAL AIRBAG | DOUBLE FRONT LATERAL AIRBAG |
| PASSENGER AIRBAG | PASSENGER AIRBAG |
| ELECTRIC WINDOW (OPERATION) | DRIVER + PASSENGER ELECTRIC WINDOW AUTO STOP |
| ON-BOARD COMPUTER | COMPUTER |
| EQUIPMENT PACK | W/O EQUIPMENT PACK |
| EXTERIOR REAR VIEW MIRROR (HEATED) | HEATED DOOR MIRROR |
| AIRBAG DEACTIVATION | MANUAL AIRBAG DEACTIVATION |
| INTERIOR DOOR CONTROL (APPEARANCE) | LION GREY LOOK INTERIOR DOOR HANDLE |
| HEADLAMP HEIGHT ADJUSTER | REMOTE MANUAL HEADLAMP ADJUSTMENT |
| FRONT SEAT GUARD | WITHOUT CAB PROTECTION PANEL |
| STORAGE (DRIVING POSITION) | WITHOUT ROOF FRONT CONSOLE STORAGE |
| RADIO RECEIVER | "RD4" RDS COMPACT DISC AUDIO SYSTEM |
| REFRIGERATION | AUTOMATIC AIR CONDITIONING |
| CRUISE CONTROL | REGULATOR AND SPEED LIMIT |
| DRIVER’S SEAT HEIGHT CONTROL | PARALLEL DRV HEIGHT ADJ |
| INTERIOR REAR VIEW MIRROR | DAY -NIGHT INNER REAR MIRROR |
| CARPET COVER | W/O CARPETMAT |
| DRIVER AIRBAG | DRIVERS AIR BAG |
| LOAD SPACE STORAGE | WITH BOOT TIDY |
| TUNER RADIO | MONO RADIO TUNER |
| OBSTACLE DETECTION SYSTEM | WITHOUT OBSTACLE DETECTOR |
| TRIM ADAPTATION | ALUMINIUM GEAR LEVER KNOB + LEATHER GAITER |
| FLOOR MAT | W/O CARPETMAT |
| EQUALISER AMPLIFIER | WITHOUT EQUALISER AMPLIFIER |
| RADIO FREQUENCY | WESTERN EUROPE RADIO FREQUENCY |
| LOCKING CONTROL | DEADLOCKING + AUTOMATIC LOCKING |
| STEERING WHEEL | LEATHER 3-SPOKE ST WHL WITH DECOR+ |
| DRIVER’S KNEE AIRBAG | WITHOUT DRIVER’S KNEE AIRBAG |
| Electrical | |
| ALTERNATOR | ALTERNATOR 120 AMP |
| BATTERY | BATTERY L2 400 |
| STARTER MOTOR | STARTER MOTOR CL 3 |
| SPECIAL LIGHTING | WITHOUT PARTICULAR LIGHT |
| MULTIPLEXING | MULTIPLEXING ASSEMBLY CAN CAN |
| Component Manufacturers | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | L5 DEPOLLUTION TAX INCENTIVE |
| ATMOSPHERIC CONDITIONS | NORMAL ATMOSPHERE |
| RADIO HEADPHONE SOCKET | WITH ACCESSORIES SOCKET |
| TRAFFIC SIDE | DRIVING ON THE LEFT-HAND SIDE |
| SIDE IMPACTS | DOOR WITHOUT REINFORCEMENT |
| SET OF KEYS | 2 HF PLIP KEYS |
| SURFACE CONDITIONS | GOOD TERRAIN |
| SPEED MONITORING | WITHOUT SPEED CHECK |
| SLAVE CONTROL UNIT | BSI COMM 2003 |
Expertamateur
- x 27
I am absolutely delighted with the detailed info you have provided from the VIN number. A lot of stuff there will make it easier for me to purchase the correct parts when I need them. It clarifies issues like exactly what model/series/build spec it is. During its production run there were variations in what was fitted to different years, etc. Many thanks for your effort.
- x 6956
No problem, just remember your membership upgrades also entitles you to request official numbers from us, just pop the request for the part you require up on the Parts thread listed on the top threads of the Citroën, DS and Peugeot main forums.
skisedr
You can use this search engine to find car specifications from the VIN : https://autoref.eu/
- x 5671
I wouldn't put any trust in that. Tried mine and it was completely wrong. Got the make and model correct but nothing more.
skisedr
Interesting. For my Peugeot it worked like a charm but I guess the result could be different according to the manufacturer
gajowy_pl
Hi,
I wonder what kind of gearbox is mounted in my Peugeot 3008 2.0hdi, as I need to change the driveshafts. Is there any chance to check by VIN please? VF3**************[VIN obfuscated, can be read by forum staff]
- x 5671
Unfortunately Stellantis have removed our option to access their database and look up details from VINs.
But perhaps a member with their own account with Stellantis may provide the details that you require.
Surgi
Hello.GiveMeABreak wrote: 24 Nov 2024, 16:09 I'm not sure what you mean by a 'genuine' VIN - that doesn't really make any sense - it will have a VIN that corresponds to the vehicle or it won't, but in either case here's your build sheet:
Vehicle Characteristics Vehicle family 307 RESTYLING AS/RP N° 10621 89 1 0847 Warranty Start Date 30/03/2006 Engine serial number 10 LH4P 1404260 BER e2*2001/116*0313*01 General Information PRODUCT TYPE PASSENGER CAR COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT VEHICLE FAMILY 307 RESTYLING SILHOUETTE COUPE CABRIOLET - 2 DOOR TRIM LEVEL UPPER HIGH ENGINE EW10A INJECTION TRANSMISSION BVM5 PAINT TYPE METALLIC PAINTWORK BODY COLOUR EZR - PAINT ALUMINIUM GREY INTERIOR TRIM TYPE BRAID ANDORRA GLOSS + EFKA "RC" UPHOLSTERY COLOUR "FX" GEARBOX (CHARACTERISTICS) GEARBOX BE4 S ENGINE (TYPE) EW/DW OTHER BADGE, " MISC. " WITHOUT FULLER BADGE BADGE CC Vehicle Characteristics TRIM LEVEL UPPER HIGH PAINT TYPE METALLIC PAINTWORK BODY COLOUR EZR - PAINT ALUMINIUM GREY INTERIOR TRIM TYPE BRAID ANDORRA GLOSS + EFKA "RC" UPHOLSTERY COLOUR "FX" GEARBOX (CHARACTERISTICS) GEARBOX BE4 S STEERING VARIABLE POWER STEERING SPEEDOMETER DRIVE CT 22 X NO Fuel Supply-Engine ENGINE EW10A INJECTION DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR CYLINDER BLOCK (MATERIAL) CRANKCASE ALUMINIUM FUEL UNLEADED PETROL 95 QUALITY A/B/E/E+ EMISSIONS STANDARD (ENGINE) EURO 4 ENGINE EMISSION CONTROL ENGINE (TYPE) EW/DW CATALYTIC CONVERTER 3-COMPONENT RHODIUM+PLATINUM FILTER CATALYSER OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER VEHICLE TECHNICAL DEPOLLUTION L5 VEHICLE TECHNICAL DEPOLLUTION PARTICLE FILTER WITHOUT PARTICLE FILTER FAN 2 FANS , 2 RATES , IMPROVED 130WAERO FUEL VAPOUR RETRIEVAL CONTROLLED PETROL VAPOUR RECUPERATION INJECTION ASSOCIATED VARIANT MOUNTING MAGNETI MARELLI TANK FILTER RESERVOIR FILTER INTERIOR STOP AND START WITHOUT STOP AND START Gearbox Transmission TRANSMISSION BVM5 GEARBOX (CHARACTERISTICS) GEARBOX BE4 S FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 19 X 77 SPEEDOMETER DRIVE CT 22 X NO WHEEL STYLE EQUINOX 16 INCH WHEEL CLUTCH HYDRAULIC CLUTCH GEARBOX TYPE (TYPE APPROVAL) GEARBOX BE4/5 S TYPE DIFFERENTIAL (GEARBOX) DIFFERENTIAL 84 RIM/TYRE SIZE 16 INCH TYRE FITMENT TYRE (SIZE, TYPE) TYRE 205/55 R16 91V NON REINFORCED WHEELS FITTED 6,5" RIM ROAD WHEELS WHEEL (TYPE) ALLOY WHEELS INFLATION PRESSURE LOSS INDICATOR WITHOUT TYRE DEFLATION INDICATOR GEARBOX TYPE GEARBOX BE4R Suspension-Steering-Brakes REAR ANTI-ROLL BAR REAR ANTI ROLL BAR DIAM 27 STEERING VARIABLE POWER STEERING FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 22 POWER STEERING FLUID COOLING SYSTEM WITHOUT POWER STEERING OIL COOLING SUSPENSION NORMAL SUSPENSION DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM BRAKE ASSOCIATED VARIANT ESP BOSCH 8 0 STEERING (OPERATION) ASSISTED ELECTROHYDRAULIC STEERING PEDAL BRACKET (TYPE) PEDAL STANDARD Body Fittings TOWBAR WITHOUT TOWBAR HORNS HORNS-HARMONY AERIAL INTEGRAL AERIAL SIDE MOULDINGS (TYPE) BODY COLOUR LATERAL PROTECTORS SIDE MOULDINGS (DIMENSION) LATERAL PROTECTORS + SIDE SILL WHEEL EMBELLISHER (STYLE) APOLLO TYPE REVERSING LAMPS WITH 1 REVERSING LAMP ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING EXT. REARVIEW MIRROR COMP. FUNCTION EXT MIRROR ELECTRIC-FOLD BACK EXHAUST TAILPIPE TRIM WITH EXHAUST OUTLET EMBELLISHER ENGINE BAY SOUNDPROOFING BONNET SOUNDPROOFING WINDSCREEN WIPER FRONT WIPER BLADE W/O RAIN SENSOR REAR SCREEN WIPER W/O REAR SCREEN WASH WIPE HEADLAMP WIPER W/O HEADLAMP WIPER FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG ROOF GLASS WITHOUT ROOF WINDOW BUMPER BODY COLOUR FRONT/REAR SPORT BUMPER WITH RUSH MUDFLAP WITHOUT REAR MUDGUARD FRONT FOGLAMP FRONT FOG LIGHTS EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) DRIVER’S DOOR MIRROR ELECTRIC CONTROL EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL SPARE WHEEL REDUCED STEEL WHEEL + NON STD TYRE EXTERIOR ACCESSORIES BODY COLOURED EXT HANDLE+FLAP TRIM+EXT MIRROR REAR SCREEN WASH W/O REAR SCREEN WASH SUN ROOF SUNROOF CONCEALABLE BUMPER TRIM BODY COLOUR BUMPER STRIP GLASS (APPEARANCE) TINTED + DARK-TINTED RR WINDOW GLASS REAR QUARTER WINDOW (TYPE) SLIDING REAR QUARTER GLASS WINDOW (TYPE) ACOUSTIC LAMINATED W/SCRREN+TOUGHENED SIDE RR RADIO-INFORMATION-COMMUNICATION PACK RD4, NO NAV, LEV C DISP, NO AMPLI-EQUALIZER Interior Fittings INTERIOR TRIM TYPE BRAID ANDORRA GLOSS + EFKA "RC" ANTI-THEFT ALARM WITH THEFT PROTECTION ALARM REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE FRONT HEAD RESTRAINT JOINTED FRONT HEADREST REAR SEAT RR BENCH SEAT 1 CUSHION SEP BACKREST NON FOLDING SUPPLEMENTARY SEAT WITHOUT SUPPLEMENTARY SEAT POSITN REAR SEAT ARMREST WITHOUT RR SEAT ARMREST LOAD FLOOR MOULDING WITHOUT LOAD FLOOR STRIP LUGGAGE COVER WITHOUT LUGGAGE COVER REAR SEATBELT REAR INERTIA-REEL SAFETY BELT FRONT SEATBELT PYROTECHNIC SEAT BELT WITH ALARM CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES SPEED GRADUATIONS SPEED GRADUATION IN MPH RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER DRIVING POSITION RIGHT HAND DRIVE ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING DASHBOARD EQUIPMENT DASHBOARD STANDARD + FACADE GREY LION INT. TRIM AND EQUIPMENT VARIATION LEATHER ST WHL AND GAITER + ALU GEAR KNOB UNDERSEAT STORAGE WITHOUT UNDER SEAT STORAGE INSTRUMENT PANEL (CHARACTERISTICS) GRAD 250 KM/H 160 MPH WHITE BGROUND CHROME CIRCLE LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS RADIO CONTROLS REMOTE RADIO CONTROL WITHOUT CD FUNCTION SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND FRONT PASSENGER SEAT HEIGHT CONTROL FRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL DRIVER’S SEAT FOLDING WITH FOLD DRIV FRONT SEATING FRONT PASSENGER SEAT FOLDING WITH FOLD PASS FRONT SEATING FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR COMPACT DISC WITHOUT COMPACT DISC STOWAGE BIN WITHOUT SETTING BOX SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM HEADLAMP BULBS HALOGEN BULB REAR WINDOW LIFT SEQENT CONTR RR WINDOW LIFTER DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW PASSENGER’S WINDOW LIFT SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER DISPLAY DISPLAY (RADIO+CLOCK,T°,CD) COURTESY MIRROR DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT FOOTREST WITHOUT FOOTREST OIL GAUGE OIL TEMP + LEVEL INDICATOR FITTING REAR HEAD RESTRAINT MOUNT 2 REAR HEAD-REST HEATING ELEMENT NON HEATED SEAT FRONT LATERAL AIRBAG DOUBLE FRONT LATERAL AIRBAG PASSENGER AIRBAG PASSENGER AIRBAG ELECTRIC WINDOW (OPERATION) DRIVER + PASSENGER ELECTRIC WINDOW AUTO STOP ON-BOARD COMPUTER COMPUTER EQUIPMENT PACK W/O EQUIPMENT PACK EXTERIOR REAR VIEW MIRROR (HEATED) HEATED DOOR MIRROR AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION INTERIOR DOOR CONTROL (APPEARANCE) LION GREY LOOK INTERIOR DOOR HANDLE HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT FRONT SEAT GUARD WITHOUT CAB PROTECTION PANEL STORAGE (DRIVING POSITION) WITHOUT ROOF FRONT CONSOLE STORAGE RADIO RECEIVER "RD4" RDS COMPACT DISC AUDIO SYSTEM REFRIGERATION AUTOMATIC AIR CONDITIONING CRUISE CONTROL REGULATOR AND SPEED LIMIT DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR CARPET COVER W/O CARPETMAT DRIVER AIRBAG DRIVERS AIR BAG LOAD SPACE STORAGE WITH BOOT TIDY TUNER RADIO MONO RADIO TUNER OBSTACLE DETECTION SYSTEM WITHOUT OBSTACLE DETECTOR INFLATION PRESSURE LOSS INDICATOR WITHOUT TYRE DEFLATION INDICATOR TRIM ADAPTATION ALUMINIUM GEAR LEVER KNOB + LEATHER GAITER FLOOR MAT W/O CARPETMAT EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY LOCKING CONTROL DEADLOCKING + AUTOMATIC LOCKING REAR QUARTER WINDOW (TYPE) SLIDING REAR QUARTER GLASS WINDOW (TYPE) ACOUSTIC LAMINATED W/SCRREN+TOUGHENED SIDE RR STEERING WHEEL LEATHER 3-SPOKE ST WHL WITH DECOR+ FAN 2 FANS , 2 RATES , IMPROVED 130WAERO DRIVER’S KNEE AIRBAG WITHOUT DRIVER’S KNEE AIRBAG Electrical ALTERNATOR ALTERNATOR 120 AMP HORNS HORNS-HARMONY BATTERY BATTERY L2 400 STARTER MOTOR STARTER MOTOR CL 3 SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT REVERSING LAMPS WITH 1 REVERSING LAMP EXT. REARVIEW MIRROR COMP. FUNCTION EXT MIRROR ELECTRIC-FOLD BACK HEADLAMP BULBS HALOGEN BULB MULTIPLEXING MULTIPLEXING ASSEMBLY CAN CAN FRONT FOGLAMP FRONT FOG LIGHTS HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT Component Manufacturers BRAKE ASSOCIATED VARIANT ESP BOSCH 8 0 INJECTION ASSOCIATED VARIANT MOUNTING MAGNETI MARELLI Miscellaneous SPECIAL SPECIFICATION L5 DEPOLLUTION TAX INCENTIVE ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE DRIVING POSITION RIGHT HAND DRIVE RADIO HEADPHONE SOCKET WITH ACCESSORIES SOCKET TRAFFIC SIDE DRIVING ON THE LEFT-HAND SIDE SIDE IMPACTS DOOR WITHOUT REINFORCEMENT SET OF KEYS 2 HF PLIP KEYS SURFACE CONDITIONS GOOD TERRAIN EXTERIOR ACCESSORIES BODY COLOURED EXT HANDLE+FLAP TRIM+EXT MIRROR SPEED MONITORING WITHOUT SPEED CHECK SLAVE CONTROL UNIT BSI COMM 2003
Gosh that's sort of ingo i am looking currently for my DS5, could you check this for my vin number please? VF7**************[VIN obfuscated, can be read by forum staff] , thanks
- x 1938
Sadly, we still do not have access to the Stellantis database for information such as this.
