Vin number lookup
Expertamateur
x 27
Vin number lookup
Unread post by Expertamateur »
I am about to purchase a Peugeot 307cc and would like to check it has a genuine VIN number. I have tried a few VIN decoder sites online but they give incomplete or confusing information. Any ideas what to do?
Absolutely hate modern cars and being ripped off by garages that play parts roulette.
PaulC5
x 675
Re: Vin number lookup
Unread post by PaulC5 »
You could put the VIN on here and hopefully admin will look it up for you.
x 6956
Expertamateur wrote: 21 Nov 2024, 15:51 I am about to purchase a Peugeot 307cc and would like to check it has a genuine VIN number. I have tried a few VIN decoder sites online but they give incomplete or confusing information. Any ideas what to do?
We can help if you need an original genuine part number, part diagram or vehicle factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 3 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Expertamateur
x 27
PaulC5 wrote: 21 Nov 2024, 21:34 You could put the VIN on here and hopefully admin will look it up for you.
OK Paul, here goes.
x 6956
I'm not sure what you mean by a 'genuine' VIN - that doesn't really make any sense - it will have a VIN that corresponds to the vehicle or it won't, but in either case here's your build sheet:
307 RESTYLING COUPE CABRIOLET - 2 DOOR 2.0 i 16v 143 (EW10A) Manual gearbox 5
Vehicle Characteristics
Vehicle family307 RESTYLING
AS/RP N°10621 89 1 0847
Warranty Start Date30/03/2006
Engine serial number10 LH4P 1404260
BERe2*2001/116*0313*01
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPEPEUGEOT
VEHICLE FAMILY307 RESTYLING
SILHOUETTECOUPE CABRIOLET - 2 DOOR
TRIM LEVELUPPER HIGH
ENGINEEW10A INJECTION
TRANSMISSIONBVM5
PAINT TYPEMETALLIC PAINTWORK
BODY COLOUREZR - PAINT ALUMINIUM GREY
INTERIOR TRIM TYPEBRAID ANDORRA GLOSS + EFKA "RC"
UPHOLSTERY COLOUR"FX"
GEARBOX (CHARACTERISTICS)GEARBOX BE4 S
ENGINE (TYPE)EW/DW
OTHER BADGE, " MISC. "WITHOUT FULLER BADGE
BADGECC
STEERINGVARIABLE POWER STEERING
SPEEDOMETER DRIVECT 22 X NO
Fuel Supply-Engine
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL)CRANKCASE ALUMINIUM
FUELUNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE)EURO 4 ENGINE EMISSION CONTROL
ENGINE (TYPE)EW/DW
CATALYTIC CONVERTER3-COMPONENT RHODIUM+PLATINUM FILTER CATALYSER
OIL COOLERMNTG WATER/OIL EXCHANGER ON ENGINE
CRANKCASE GAS CIRCUIT HEATINGW/O HEATER CASING GAS CIRCUIT
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
VEHICLE TECHNICAL DEPOLLUTIONL5 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTERWITHOUT PARTICLE FILTER
FAN2 FANS , 2 RATES , IMPROVED 130WAERO
FUEL VAPOUR RETRIEVALCONTROLLED PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANTMOUNTING MAGNETI MARELLI
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITHOUT STOP AND START
Gearbox Transmission
TRANSMISSIONBVM5
FINAL DRIVE RATIOREAR AXLE HYPOID GEARSET 19 X 77
WHEEL STYLEEQUINOX 16 INCH WHEEL
CLUTCHHYDRAULIC CLUTCH
GEARBOX TYPE (TYPE APPROVAL)GEARBOX BE4/5 S TYPE
DIFFERENTIAL (GEARBOX)DIFFERENTIAL 84
RIM/TYRE SIZE16 INCH TYRE FITMENT
TYRE (SIZE, TYPE)TYRE 205/55 R16 91V NON REINFORCED
WHEELS FITTED6,5" RIM ROAD WHEELS
WHEEL (TYPE)ALLOY WHEELS
INFLATION PRESSURE LOSS INDICATORWITHOUT TYRE DEFLATION INDICATOR
GEARBOX TYPEGEARBOX BE4R
Suspension-Steering-Brakes
REAR ANTI-ROLL BARREAR ANTI ROLL BAR DIAM 27
FRONT ANTI-ROLL BARFRONT ANTI-ROLL BAR DIAM 22
POWER STEERING FLUID COOLING SYSTEMWITHOUT POWER STEERING OIL COOLING
SUSPENSIONNORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANTESP BOSCH 8 0
STEERING (OPERATION)ASSISTED ELECTROHYDRAULIC STEERING
PEDAL BRACKET (TYPE)PEDAL STANDARD
Body Fittings
TOWBARWITHOUT TOWBAR
HORNSHORNS-HARMONY
AERIALINTEGRAL AERIAL
SIDE MOULDINGS (TYPE)BODY COLOUR LATERAL PROTECTORS
SIDE MOULDINGS (DIMENSION)LATERAL PROTECTORS + SIDE SILL
WHEEL EMBELLISHER (STYLE)APOLLO TYPE
REVERSING LAMPSWITH 1 REVERSING LAMP
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTIONEXT MIRROR ELECTRIC-FOLD BACK
EXHAUST TAILPIPE TRIMWITH EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFINGBONNET SOUNDPROOFING
WINDSCREEN WIPERFRONT WIPER BLADE W/O RAIN SENSOR
REAR SCREEN WIPERW/O REAR SCREEN WASH WIPE
HEADLAMP WIPERW/O HEADLAMP WIPER
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
ROOF GLASSWITHOUT ROOF WINDOW
BUMPERBODY COLOUR FRONT/REAR SPORT BUMPER WITH RUSH
MUDFLAPWITHOUT REAR MUDGUARD
FRONT FOGLAMPFRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE)DRIVER’S DOOR MIRROR ELECTRIC CONTROL
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE)PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
SPARE WHEELREDUCED STEEL WHEEL + NON STD TYRE
EXTERIOR ACCESSORIESBODY COLOURED EXT HANDLE+FLAP TRIM+EXT MIRROR
REAR SCREEN WASHW/O REAR SCREEN WASH
SUN ROOFSUNROOF CONCEALABLE
BUMPER TRIMBODY COLOUR BUMPER STRIP
GLASS (APPEARANCE)TINTED + DARK-TINTED RR WINDOW GLASS
REAR QUARTER WINDOW (TYPE)SLIDING REAR QUARTER GLASS
WINDOW (TYPE)ACOUSTIC LAMINATED W/SCRREN+TOUGHENED SIDE RR
RADIO-INFORMATION-COMMUNICATION PACKRD4, NO NAV, LEV C DISP, NO AMPLI-EQUALIZER
Interior Fittings
ANTI-THEFT ALARMWITH THEFT PROTECTION ALARM
REAR HEAD RESTRAINTREAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINTJOINTED FRONT HEADREST
REAR SEATRR BENCH SEAT 1 CUSHION SEP BACKREST NON FOLDING
SUPPLEMENTARY SEATWITHOUT SUPPLEMENTARY SEAT POSITN
REAR SEAT ARMRESTWITHOUT RR SEAT ARMREST
LOAD FLOOR MOULDINGWITHOUT LOAD FLOOR STRIP
LUGGAGE COVERWITHOUT LUGGAGE COVER
REAR SEATBELTREAR INERTIA-REEL SAFETY BELT
FRONT SEATBELTPYROTECHNIC SEAT BELT WITH ALARM
CLIMATE (AMBIENT TEMP)TEMPERATE COUNTRIES
SPEED GRADUATIONSSPEED GRADUATION IN MPH
RADIO EQUIPMENTFEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
DRIVING POSITIONRIGHT HAND DRIVE
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENTDASHBOARD STANDARD + FACADE GREY LION
INT. TRIM AND EQUIPMENT VARIATIONLEATHER ST WHL AND GAITER + ALU GEAR KNOB
UNDERSEAT STORAGEWITHOUT UNDER SEAT STORAGE
INSTRUMENT PANEL (CHARACTERISTICS)GRAD 250 KM/H 160 MPH WHITE BGROUND CHROME CIRCLE
LOUDSPEAKER4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
RADIO CONTROLSREMOTE RADIO CONTROL WITHOUT CD FUNCTION
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF)WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT
DRIVER SEAT CONTROLDRIVERS FRT SEAT MANUAL CNTROL
DRIVER’S SEAT FOLDINGWITH FOLD DRIV FRONT SEATING
FRONT PASSENGER SEAT FOLDINGWITH FOLD PASS FRONT SEATING
FRONT SEAT ARMRESTASSEMBLY WITHOUT FRONT ELBOW REST
EXTERIOR TEMP. INDICATOREXT TEMP INDICATOR
COMPACT DISCWITHOUT COMPACT DISC
STOWAGE BINWITHOUT SETTING BOX
SATELLITE NAVIGATION SYSTEMWITHOUT NAVIGATION SYSTEM
HEADLAMP BULBSHALOGEN BULB
REAR WINDOW LIFTSEQENT CONTR RR WINDOW LIFTER
DRIVER’S WINDOW LIFTSEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFTSEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
DISPLAYDISPLAY (RADIO+CLOCK,T°,CD)
COURTESY MIRRORDRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT
FOOTRESTWITHOUT FOOTREST
OIL GAUGEOIL TEMP + LEVEL INDICATOR
FITTING REAR HEAD RESTRAINTMOUNT 2 REAR HEAD-REST
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGDOUBLE FRONT LATERAL AIRBAG
PASSENGER AIRBAGPASSENGER AIRBAG
ELECTRIC WINDOW (OPERATION)DRIVER + PASSENGER ELECTRIC WINDOW AUTO STOP
ON-BOARD COMPUTERCOMPUTER
EQUIPMENT PACKW/O EQUIPMENT PACK
EXTERIOR REAR VIEW MIRROR (HEATED)HEATED DOOR MIRROR
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE)LION GREY LOOK INTERIOR DOOR HANDLE
HEADLAMP HEIGHT ADJUSTERREMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SEAT GUARDWITHOUT CAB PROTECTION PANEL
STORAGE (DRIVING POSITION)WITHOUT ROOF FRONT CONSOLE STORAGE
RADIO RECEIVER"RD4" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLREGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROLPARALLEL DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRRORDAY -NIGHT INNER REAR MIRROR
CARPET COVERW/O CARPETMAT
DRIVER AIRBAGDRIVERS AIR BAG
LOAD SPACE STORAGEWITH BOOT TIDY
TUNER RADIOMONO RADIO TUNER
OBSTACLE DETECTION SYSTEMWITHOUT OBSTACLE DETECTOR
TRIM ADAPTATIONALUMINIUM GEAR LEVER KNOB + LEATHER GAITER
FLOOR MATW/O CARPETMAT
EQUALISER AMPLIFIERWITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCYWESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROLDEADLOCKING + AUTOMATIC LOCKING
STEERING WHEELLEATHER 3-SPOKE ST WHL WITH DECOR+
DRIVER’S KNEE AIRBAGWITHOUT DRIVER’S KNEE AIRBAG
Electrical
ALTERNATORALTERNATOR 120 AMP
HORNSHORNS-HARMONY
BATTERYBATTERY L2 400
STARTER MOTORSTARTER MOTOR CL 3
SPECIAL LIGHTINGWITHOUT PARTICULAR LIGHT
MULTIPLEXINGMULTIPLEXING ASSEMBLY CAN CAN
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONL5 DEPOLLUTION TAX INCENTIVE
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
RADIO HEADPHONE SOCKETWITH ACCESSORIES SOCKET
TRAFFIC SIDEDRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTSDOOR WITHOUT REINFORCEMENT
SET OF KEYS2 HF PLIP KEYS
SURFACE CONDITIONSGOOD TERRAIN
SPEED MONITORINGWITHOUT SPEED CHECK
SLAVE CONTROL UNITBSI COMM 2003
Expertamateur
x 27
I am absolutely delighted with the detailed info you have provided from the VIN number. A lot of stuff there will make it easier for me to purchase the correct parts when I need them. It clarifies issues like exactly what model/series/build spec it is. During its production run there were variations in what was fitted to different years, etc. Many thanks for your effort.
x 6956
No problem, just remember your membership upgrades also entitles you to request official numbers from us, just pop the request for the part you require up on the Parts thread listed on the top threads of the Citroën, DS and Peugeot main forums.
skisedr
Unread post by skisedr »
You can use this search engine to find car specifications from the VIN : https://autoref.eu/
x 5671
I wouldn't put any trust in that. Tried mine and it was completely wrong. Got the make and model correct but nothing more.
skisedr
Interesting. For my Peugeot it worked like a charm but I guess the result could be different according to the manufacturer
gajowy_pl
Unread post by gajowy_pl »
Hi,
I wonder what kind of gearbox is mounted in my Peugeot 3008 2.0hdi, as I need to change the driveshafts. Is there any chance to check by VIN please? VF3**************[VIN obfuscated, can be read by forum staff]
x 5671
Unfortunately Stellantis have removed our option to access their database and look up details from VINs.
But perhaps a member with their own account with Stellantis may provide the details that you require.
Surgi
Unread post by Surgi »
GiveMeABreak wrote: 24 Nov 2024, 16:09 I'm not sure what you mean by a 'genuine' VIN - that doesn't really make any sense - it will have a VIN that corresponds to the vehicle or it won't, but in either case here's your build sheet:
General Information
TRANSMISSIONBVM5
ENGINE (TYPE)EW/DW
BADGECC
Fuel Supply-Engine
ENGINE (TYPE)EW/DW
TRANSMISSIONBVM5
Body Fittings
HORNSHORNS-HARMONY
Interior Fittings
Electrical
HORNSHORNS-HARMONY
Miscellaneous
Hello.
Gosh that's sort of ingo i am looking currently for my DS5, could you check this for my vin number please? VF7**************[VIN obfuscated, can be read by forum staff] , thanks
x 1938
Sadly, we still do not have access to the Stellantis database for information such as this.
Surgi
