DIY Car Maintenance with function over finesse!!
- x 8409
Re: DIY Car Maintenance with function over finesse!!
Excellent! Pleased to see the result of your visit to the test centre Ryan
- x 3565
If Jim starts coming at me with a bent spanner, then I'll just distract him with a picture of a shiny AX. He'll be just like a budgie pecking at a mirror if I show him one of thoseRp0thejester wrote: 24 Oct 2024, 14:55 Make sure you take that spanner with you on Tuesday incase Bobins starts playing up!
- x 1074
Show him a picture of a white one!! That's the only Tricolour that he's missing!!
Champion of Where's CitroJim
- x 8409
bobins wrote: 24 Oct 2024, 17:54If Jim starts coming at me with a bent spanner, then I'll just distract him with a picture of a shiny AX. He'll be just like a budgie pecking at a mirror if I show him one of thoseRp0thejester wrote: 24 Oct 2024, 14:55 Make sure you take that spanner with you on Tuesday incase Bobins starts playing up!![]()
I used to have a white one Ryan... Daffodil. Now living with AlasdairRp0thejester wrote: 24 Oct 2024, 18:16 Show him a picture of a white one!! That's the only Tricolour that he's missing!!
Space and resource limitations rule me out of having custody of a third. Happily, I still get to see Daffodil on regular occasions and have a little play with her
- x 1074
That just sounds weird.... might want to edit that
- x 8409
Daffodil enjoys a good spannering every now and again
- x 1074
- x 8126
I managed to get the next stage materials together yesterday so after the cricket I hope to start putting it together!!
- x 1074
HELLO..... I've been waiting on the thread all day.... Have you built it yet!?
- x 8126
Yes and no!!! I built it and on the third test run before taking any pics the speed controller went 'straight through' and I just got full voltage at the motor, not acceptable so I dismantled it again and am in discussion with the supplier!! More news as and when!!
- x 8126
An update on the project ............ it's still awaiting my replacement speed controlling device!!
- x 8126
Well the new speed controlling device from China arrived and this morning I decided to begin butchering the variable speed hammer drill which I found brand new on ebay for £18.50 here and headed for the garage. As I opened the box a different idea occurred to me, maybe I could rig a temporary mount using the drill as it is rather than butcher it for the controller!! So I took a few measurements by eye and got out the jig saw to produce a mounting board:
I decided to use the drive belt as part of the stabilising kit so I could apply downward tension with cable ties. (Remember the whole thing has to be easily dismantled and assembled so SWMBO can park in the garage!) So I started applying cable ties until I was satisfied that I had a firm fixing:
Having got it secure I was able to tension the belt by easing the hub up in the workmate jaws and managed to get it pretty accurate. So I turned it on!!
So I put that down as a success, especially as I have kept the expensive chinese drill (included spare brushes , 3 drill bits, chuck key and depth guage!) intact to replace my old proper mains hammer drill which died a couple of years ago
- x 8409
Looking good Mick
- x 1074
It runs....so does Jim!! Doesn't mean it's any good.....shots fired.....mickthemaverick wrote: 09 Nov 2024, 12:59 Well the new speed controlling device from China arrived and this morning I decided to begin butchering the variable speed hammer drill which I found brand new on ebay for £18.50 here and headed for the garage. As I opened the box a different idea occurred to me, maybe I could rig a temporary mount using the drill as it is rather than butcher it for the controller!! So I took a few measurements by eye and got out the jig saw to produce a mounting board:
So I put that down as a success, especially as I have kept the expensive chinese drill (included spare brushes , 3 drill bits, chuck key and depth guage!) intact to replace my old proper mains hammer drill which died a couple of years ago![]()
- x 8409
Rp0thejester wrote: 09 Nov 2024, 22:21 It runs....so does Jim!! Doesn't mean it's any good.....shots fired.....![]()
