206cc to a 308cc How ? Why ? Everything 308cc
Huskyxantia
x 918
Re: 206cc to a 308cc How ? Why ? Everything 308cc
Unread post by Huskyxantia »
:-D
Huskyxantia
x 918
Im still to do the above , when ive time , good weather and so on
Ive a 20inch light bar which will be very useful were im located as some of my routes are very dark & lonely old back roads. Photos and hints will be posted when i undertake this job.
:-D
Huskyxantia
x 918
Window drop, wont go into to much about this as theres enough already on here regarding this issue, i had to replace a door handle as the sensor was dropping and closing the window while driving or parked up . If you need to remove the door card.
Different car but same way of removing the handle
I dont own this videos just posting for refernce for any one who needs help
:-D
x 2356
Unread post by MattBLancs »
It's surprisingly easy to get the handles off when you know how, isn't it!
On the lighting bar, could it potentially sit behind the grille? Worth popping the bumper off for a try (I've always found bumper removal a job that seems to turn out much less involved than I'd imagined. Not done the 308 as yet mind you!)
Huskyxantia
x 918
Most peugoets are the same might just have to odd slight differ in clips and screw locations but there all simliar, the wing to bumper is the pain in the ar
Sbecause of the way the wing / bumper clip and or 10mm bolt to each other, most ive seen have 10mm bolt then its clipped , bolt always is rusted to bits and ends up snapoing the plastic !
:-D
x 2356
Huskyxantia wrote: 05 Nov 2024, 18:22 Most peugoets are the same might just have to odd slight differ in clips and screw locations but there all simliar, the wing to bumper is the pain in the ar
Yes, seems so. Quite a good system really. I put a bit of Red Rubber grease on the contact points and makes a noticeable improvement to ease and "feel" of the handle in use.
Because of the way the wing / bumper clip and or 10mm bolt to each other, most ive seen have 10mm bolt then its clipped , bolt always is rusted to bits and ends up snapoing the plastic !
Ah I've just been lucky this far then! No doubt jinxed my next bumper removal then! D'oh! :-D
Huskyxantia
x 918
I wired the live from the side light live . When its on its on but then the switch works the light bar via the relay and so on.
:-D
Huskyxantia
x 918
So, the door strap was really making a noise so its been removed & a new one has been ordered, door card off, speak out then hole to get your hand in to reach the strap , a hex bolt on the door post & 2 10mm nuts holding the strap to, bolt off nuts off too then remove via speaker hole, refit reverse of removal , theres a video on here of how to remove door card , i dont own the video its posted as educational use. Photos not in order but im sure they can tell the story.
:-D
Huskyxantia
x 918
Nylon roller on these parts wear out , then that horrible clonk knock noise when you open n close the door
:-D
Huskyxantia
x 918
When i took the door car off i noticed this spare loom
Any idea what it is for ? Door mirror is all plugged in so is the speaker .
I assume my door mirrors have the deicing feature which i think they do as i recall the mirrors deicing last winter when the demist feature was used . So any body know ? Maybe it could be used to power something else ?
:-D
Huskyxantia
x 918
Door strap replaced with a DS4 strap
Which is a perfect upgrade can be found here. https://www.ebay.co.uk/itm/133163362405 ... media=COPY
:-D
Huskyxantia
x 918
When removing the cubby hole in the main dash console just under the stereo there is a small loom with plug sitting in a little housing its not being used and im wondering if this could power a dash clock like the ones in the rcz cars ? Has anyone seen this loom & know what it could be for.
:-D
x 1463
Unread post by xantia_v6 »
Maybe it is something to do with the optional CD changer? Some wire codes and plug description would help identify it.
Huskyxantia
x 918
Possible , must ASK for a diagrame for looms regarding this , i'll wait to see if one pops up .
:-D
ChrisRobin
x 104
Unread post by ChrisRobin »
@ Huskyxantia "Door strap replaced with a DS4 strap
Which is a perfect upgrade can be found here. https://www.ebay.co.uk/itm/133163362405 ... media=COPY"
And you fitted this DS4 strap to your 308CC?
fits and works Ok?
Reason I ask I changed the wife's driver door strap and now the passenger is clonking when you open, I did the same on my Megane CC the 1st time I bought a Coupe check strap it looked the same from the image, the guy on Ebay said it is the same, same size door, but when it ws fitted it didn't fit as the CC had a slight bend in the rod were as Coupe was straight, so I would be interested to know if this DS4 strap fitted your 308CC and works ok as they are hefty doors, I think I paid in the region of £35 for her 308cc strap, so a tenner is a bargain if it works ok.
Just Remember;Where ever you go, There you are !
