C4gp 2014 1.6 ehdi auto juddering
Naismith624
Unread post by Naismith624 »
Hi all,
Currently have 2014 C4GP 1.6 E-Hdi and having juddering when pulling away. Currently 110k on clock and have only had just over a year and had gradually got worse. Tried hard reset (foot to floor till 3rd) and not made any difference. Engine code is DV6CSTT which i can't find much information about so my question is - is this the engine that it came from factory? and not been replaced with another? and I'm unable to see gearbox code Vin is VF7**************[VIN obfuscated, can be read by forum staff] if anyone could point me in the right direction I'd be most grateful thanks
x 1502
Re: C4gp 2014 1.6 ehdi auto juddering
Most likely it needs a new clutch, it's doing very well if it got to 110k on the original!
Naismith624
It was my first thoughts but do automatics have clutches I thought was torque converter? Thanks
x 6950
You don't have an automatic gearbox. You have a manual gearbox and clutch, but this system is piloted, so has hydraulic actuators to do the gear and clutch changes. There is no torque converter.
So as Richard says if it starts to get a bit jerky, it likely needs a clutch and almost certainly a new dual mass flywheel, as it's sensible to do this at the same time as the clutch to save on labour. Be careful who you choose do get it done with - I would advise on getting it to a specialist who knows these systems as the gearbox and clutch have to be programmed after replacement of the clutch and not everyone has the tools / know-how to work on these properly. Otherwise a dealer will be best - will cost a little more, but they will know what they're doing.
Naismith624
Thankyou very much for that information. Learn something new everyday i would have never thought its a manual gearbox being labeled an "auto". Are you able to help me regarding gearbox code? so I know what parts to order for the replacement of said parts
x 6950
Happy to provide you with parts information, but please see below:
We can help if you need an original genuine part number, part diagram or vehicle factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 3 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
