Dpf regen
OnlineRichardW
- x 1486
Re: Dpf regen
Not really, if the rear window is wet or steamed up you might see that the heater element has come on. If you're mostly doing fast A roads, then it may be managing with passive regen, of which there will be no sign!
john79
Re: Dpf regen
no rear windows in my van mate lol. my Audi a3 i can tell when it;s doing a regen , its more poky the engine sound's different and it idies higher .
shtu
- x 76
Re: Dpf regen
I don't know if this works on a K9, but there is a way on the B9, https://www.berlingoforum.com/thread-19837.html
Huskyxantia
- x 904
Re: Dpf regen
My 308cc regens about every 6th week 20mins motorway all good.
Husky.
Steve Walsh
- x 516
Re: Dpf regen
I soldered in a LED behind the drivers side mirror on my last car, connect to the 2 heater wires and attach to the rear of the glass with some glue so that you can see it in the gap between glass and housing..
Planning on doing it to my latest one when I get time
- x 1068
Re: Dpf regen
If you do that, could you post a how to with photos, I would be interested in seeing how it's done.
Champion of Where's CitroJim
Steve Walsh
- x 516
Re: Dpf regen
Rp0thejester wrote: 30 Oct 2024, 18:44 by Rp0thejester » Yesterday, 19:44
[/quote
Just done it this morn, 30 mins start to finish.
Tilt glass in and up and use fingers or plastic pry tool to pop out glass, The heater wires are the white plug, the one with the stripe is positive but check with a meter or LED, LED will only work the right way, run engine and turn mirror heaters on to identify which one if needed. Mark the positive one on the plug
I used a terminal tool to remove the 2 spade connectors from the white plug, You can bare the wires if you didn't want to do that. You can run the car again to test before going any further. I then measured the LED Diameter and drilled a hole to poke it through so it will be visible when glass back in housing, secure it with silicon or glue gun, I also secured the extra length of wire with a blob from the glue gun. Pop the glass back in and that's it done. When car having a regen red light will come on, also when heated mirrors on.. Hope this all makes sense.
Steve Walsh
- x 516
Re: Dpf regen
Photo's loaded in reverse order..... oops
- x 6957
Re: Dpf regen
Just be advised that the engine ECU employs different strategies and levels of assisted regeneration depending on the circumstances of the vehicle, and driving conditions, so may not actually switch on the power consuming devices unless needed.
Djandree
- x 38
Re: Dpf regen
Look at my post
viewtopic.php?t=82188
is working perfectly on hdi engines with adblue. In my case (1.5HDI) going on short distances DPF is regenerating every 150 miles, on longer motorway drive 200 - 220 miles
- x 6957
Re: Dpf regen
The Adblue is irrelevant though as it won't have anything to do with regeneration of the particle filter
I was just stating the way these work - so the engine management system decides if and when power consumers need to be switched on - it may just use post-injection or natural regeneration, so not a 100% guarantee this will work in all cases, all the time.
Huskyxantia
- x 904
Re: Dpf regen
Just remember to mention the led to the new owner when or if you sell the car on., if it was me id be ... whys my alarm led on lol.
Husky.
Huskyxantia
- x 904
Re: Dpf regen
4got to mention, mainly my coolant system fans get used during a regen so far thats all ive noticed , so i may try this led trick my self , even if it becomes an idicator for the heated mirrors , and i do think this led idea is pretty smart.
Husky.
Mihael_M
- x 37
Re: Dpf regen
I also installed Led, but I thought that it was easier and better to install it and to see it from the inside of the door. Now it is visible to me even when the sun is bright.
