Hi,
Have problem with a 407 1.6hdi.
The code is p0069 and I have checked the map sensor and its fine. The fault pop up direct when the ignition is turned on, without starting the engine.
Turbo boost pressure seems correct against the actual real atmospheric pressure (976mbar) with the engine off. Checked this value with another car that also showed 980mbar.
But the atmospheric pressure that the ecu reads is way off, 765mbar.
Does anyone knows where this barosensor located? Is it located in the ecu?
Best regards
Rikard Andersson
Peugeot 407 1.6hdi P0069
LedZep
- x 30
Re: Peugeot 407 1.6hdi P0069
To get the idea.Maybe it helps.
Reason: YouTube link.
Husqy
I have changed the map sensor without any luck. I attached a picture from diagbox.
Husqy
The differens between turbo pressure and atmospheric pressure to big.
But where is the sensor that delivers this atmospheric value?
LedZep
- x 30
This is measured by MAP sensor and is located by his name, in manifold (Manifold Atmospheric Pressure).Is the right s/n sensor that you replace in manifold and that is good quality? You have to check also power and grounds of sensor plug and signal, as fuses or relay. The way is described in video after 4.15. I think the video is exactly your case scenario fault.
Husqy
When the ignition is turned on the ecu compare the map senor value against a other pressure sensor to check that the sensors work correctly. Map sensor seems to be called turbo pressure in diagbox, and I wondering where the other sensor I located that gives the signal for atmospheric pressure.
Most likely it is placed directly on the pcb of the ecu, but I'm not sure.
And MAP = manifold absolute pressure, not atmospheric.
LedZep
- x 30
You are right.A copy/paste accident., If there is a pressure sensor embedded in ECU, is not good news.
- x 6963
You haven't specified the exact engine, so I'm assuming this is a DV6TED4 (VIN will help):
| Fault Code: | P0069 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
Husqy
Thanks for the detailed information of the code.
So is there anyone that could confirm that the atmospheric sensor is placed in the ecu?
- x 6963
You haven't provided a VIN, so I can't even begin to look into this. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Husqy
We had a 12 month pause, but now we are working with this car again.
The vin number is VF3**************[VIN obfuscated, can be read by forum staff].
When I have diagbox connected the atmospheric pressure is all over the place. Varying between 600mbar to 750mbar.
Permanents fault are now:
P0069
P0490
P1162
P1351
P0409
New delphi erg valve part number: eg10507 12v1 is mounted and a new intake pressure sensor. The egr is programed with diagbox, but it seems to fail.
Did some measurement between the ecu and egr connector and the cables seems to be okay. When I do the actuator test the valve moves okay.
So what to do next. Could the problem be the Ecu?
P0069
P0490
P1162
P1351
P0409
Husqy
So, have this car a barometric sensor to measure the atmospheric pressure, and if so where could it be placed?
PaulC5
- x 653
It may be inside the ecu.
