C4 Picasso - Middle 12v socket
kg03mry
Unread post by kg03mry »
Hi
I have a 2017 C4 Picasso 1.6hdi.
The middle 12v socket in the car isn't working as it was overloaded. So far I've taken out the glove box and tested all the visible fuses, including the bottom rows of the fuse box behind. I've tested all the fuses under the hood. I've taken the middle trim out to get to the sockets cable hoping I'd be able to trace it back to the fuse box, but it seems to go deep inside the car. Socket is continuity testing okay.
The front and boot socket are both working fine.
Does anybody know where the cable for the socket comes out? Or are there any wiring diagrams available?
Thanks in advance for the help 🤙
PaulC5
x 675
Re: C4 Picasso - Middle 12v socket
Unread post by PaulC5 »
Did you look in the handbook at the fuse list to see which fuse it should be ? If you do not have the handbook you can find them here viewtopic.php?t=63208
Dedpiksil
Unread post by Dedpiksil »
Middle centre console 12v cigarette fuse location
Just reviving this old thread to help anyone who was also stumped by the location of the middle/ centre console 12 cigarette fuse location - it's behind the first fuse board you see (after taking apart the glovebox). You have to arch your head right under to see it. It's the blue 15a fuse you see in my photo.
