Citroen Owner Handbooks
x 6955
If you don't have your Citroen owner's manual, you can view most of them online or in most cases download a copy as a PDF, or in some cases just the relevant section required.
Not all early models are included.
  • Just follow the link, select your preferred language from the top right corner
  • Then select the model
  • Now select the car image and finally the build date of your vehicle
Note: Be wary of the owners manual versions for left hand drive vehicles, which the following images circled in Yellow represent as an example.
These are searchable for content, and if they are available as a download, there should be a PDF icon shown. Click on this and it will either give you the option to save the file, or will open in a browser window. Once the file has loaded, you can save the file as a PDF to a location of your choice.
Bear in mind some of these can be 400+ pages for some newer models with loads of options, so may take a little while to download for some users depending on your broadband speed.
Citroen Owner Handbooks Link
Note: These are Owner Reference Handbooks for the Equipment and Operation - not Mechanical manuals.
