Injectors misbehaving but trying to understand the numbers
darbuck
x 289
Re: Injectors misbehaving but trying to understand the numbers
Unread post by darbuck »
Well rained off again, had to put her on charge to get into the boot. A few pictures for you.
Darren
darbuck
x 289
I'm going to try a hairdryer just to be sure it should show if there is significant back pressure at higher airflows I think 🤔
Darren
darbuck
x 289
Tried the hairdryer good flow through the cat so happy it won't damage the new turbo #-o
Darren
x 2348
Unread post by MattBLancs »
darbuck wrote: 25 Aug 2024, 13:21 Tried the hairdryer good flow through the cat so happy it won't damage the new turbo #-o
That's all well and good, but don't leave us in suspense...
Spoiler: show
... What did it do for your hair!?
:rofl2:
darbuck
x 289
:rofl2: I was thinking on perming it but it would probably blow away 🤣🤣.
Still very damp here so I don't think I will be back under the car today. I think herself wants me to do gardening 😭
Darren
No10Chris
Unread post by No10Chris »
Personally I wouldn’t use a slide hammer injector remover,
Slightly out of line and it will snap,,
I have a traffic which are known for stuck injectors, bought a kit on eBay and got them out
darbuck
x 289
The only thing that would pull them was the hydraulic puller. I made up a mechanical puller first and it done nothing and neither did the slide hammer.
Darren
darbuck
x 289
Ok so turbo and pre-cat are in I put a bit of a how to in a different post related to the turbo. Just need to connect up other bits and prime the turbo. I'm contemplating doing a compression test but cant decide if it is worth the hassle. At this point?
Darren
x 2348
Never done a compression test on a diesel - does it connect via injector or glue plug hole?
If it's glow plugs, having snapped one in the past, I'd leave it for another day!
darbuck
x 289
It's glow plug on these, I think you might be right. Leave it alone put it back together and see how I get on. If there's a problem then maybe do one I suppose. I have a scope with the amp clamp that you can do a relative compression test with, but I haven't figured out how to do it. I'll have to watch a few more videos on it. It's non invasive. But I smoke tested the engine before and didn't find any leaks from the cylinders so probably just over thinking again.
I'll have to practice the relative test I think just for peace of mind. It measures amps as a function of cylinder pressure essentially.
Darren
darbuck
x 289
So turbo is fully installed I gave the intercooler and pipes a good cleaning just to be safe and I reinstalled the cat and Dpf and smoke tested the exhaust for leaks and everything seems fine no visible leaks. Just the drive shaft and engine mount left to do. Then refill gearbox and engine with fresh oil. I did however have a slight issue with the temperature sensor in the Dpf . It's a little bit bent , I'm not sure what happened it. I haven't tested it yet I'll wait until everything is back together and check for live data.as long as it returns data I should be good. If not I will just have to buy a replacement. I put a new high pressure a/c pipe in as well, mine had a pin hole in it and being aluminium it's hard to find someone willing to weld it , my mate tried but it kept bubbling up and leaving more holes so couldn't get it to work. I have to test the new one is airtight as well. The jobs on this car just seem endless at this point.
Darren
KennyW
x 165
Unread post by KennyW »
All I can do Darren is keep giving you encouragement to keep at it. Your car is going to be as good as new.
Kenny
C3 1.4 petrol (SWMBO)
darbuck
x 289
Hi Kenny, thanks, how are you all good I hope. I was away on Friday and part of Saturday went to the beach it was glorious weather. I appreciate the encouragement.
Darren
darbuck
x 289
Does anyone know if it's possible to get a metal dipstick for the C5 x7 2.0 hdi the one in mine is plastic which I don't trust
Darren
x 2348
I don't like them either, but I've put it on my "not worth worrying about" list. The DV6 has a plastic one - my wife's 206 HDi came with the end missing (wasn't down the dipstick tube so who knows where that bit actually went!?) but it's (cheap) replacement lasted ok.
