Issue in a hurry Peugeot 3008 hybrid
trollkarlen
- x 4
Im looking into buying a used Peugeot 3008 hybrid4 with an 2 error codes. No engine light but warning when trying electric only mode. I just want to know the severity of theses. The Price on the car is good.
Vin: VF3**************[VIN obfuscated, can be read by forum staff]
Error codes
1059
16AB
Thanx in advance
Error codes
1059
16AB
Thanx in advance
- x 6955
Re: Issue in a hurry Peugeot 3008 hybrid
Can't help you with those codes as they are not proper fault codes - far too short. What I can tell you is that this specific vehicle has an outstanding after-sales campaign from June 2024 to remove and replace the traction battery. This will be free, so no charge by the dealer. This may be why there are faults and why it has to be replaced.
MQE - 3008 (P84), 508 (R8) - Traction battery
Replace the traction battery. Return the traction battery following the below described return procedure.
trollkarlen
- x 4
Sounds nice with a new traktion battery for free
I did not bring my computer with servicebox offline so could not check it myself. So the error codes are from an auto-com system, but it could not decode the manufactory codes. See attachment. Motorelektonik is Swedish for engine elektonics
Okänd felkod is Swedish for Unknown error code
The Traction Battery charges and the car runs on hybrid using all engines. But it always keeps the ice running, i checked the auxiliary battery in the trunk and it had only 2.5v so maybe that is the culprit.
Does the auxiliary battery change from the ice or traction battery? Maybe both? I want to test if its the charging or the battery thats at fault. I have it on charging during the evening and will see tomorrow.
Any input would be helpful.
I will arrive home tomorrow evening and connect offline servicebox to see what it says.
trollkarlen
- x 4
After I charged the auxiliary battery the warning disappeard and it started in electric only mode
And also in that mode the voltage over the auxiliary battery was almost 14 volts so it looks like its charging it from the Traction Battery. So maybe the auxiliary battery needs changing.
Does anyone have the specs for the auxiliary battery?
Amp, chemistry, size and connection?
Is the recall for the Traction Battery independent on the miles the car have traveled?
- x 6955
No, it has only just been issued and is a no charge operation regardless. I suggest you get it booked in as soon as possible if you decide to purchase it, as there are known issues with some of these batteries, so I wouldn't leave it.
trollkarlen
- x 4
I bought it and booked it right away. They will get back to me when the parts have arrived
Super input GiveMeABreak
Need to do service on it also and change the transmission oil is it the same as for the EAT8 normal gearbox (AW2 Oil)?
Is the AW2 the quality or whats the oem nr for it if i want to buy other brands? Or thats a bad idea?
Like this one?
https://www.trodo.se/vaxelladeolja-febi-bilstein-183413
Peugeot oe
16 350 560 80
Like this one?
Peugeot oe
16 350 560 80
- x 6955
Yes, AW2 is the correct oil.
trollkarlen
- x 4
Thanx!
You suggest the huile aw2 orginal or is it ok with other brands with aw2 compatible?
- x 6955
As with all oil there will be cheaper brands, so it's up to you, but make sure it specifies it's AW2 specifically.
trollkarlen
- x 4
I got the real codes but my diagbox was too old so it could not decode it 9.68
Could someone assist?
ECU
P105904
P16AB07
EAT8
P140605
P17E049
Parking assistance
U1F0000
B124497
B125192
ADAS
B1004 96
U1F00 00
BSI
B120D 86
B120A ?? Warning collision, permanent
Service module
8D93
Which version of diagbox for at least 2020 models?
The main issue now is the collision detect and lane assist warnings.
ECU
P105904
P16AB07
EAT8
P140605
P17E049
Parking assistance
U1F0000
B124497
B125192
ADAS
B1004 96
U1F00 00
BSI
B120D 86
Service module
8D93
- x 6955
Sorry, I don't currently have the descriptors for this engine.
trollkarlen
- x 4
Oki, thanx for checking
Is this the oe number for front coil even for my vin ?
It fits the other 3008, but maybe the hybrid4 is heavier?
PEUGEOT
9815469280
PEUGEOT
9815469280
trollkarlen
- x 4
Whats the procedure to disconnect the battery.
I read somewhere that you should open the hood and then close all the doors. Wait until the car sleeps and then 5min disconnect the main battery. And then the auxiliary battery. But how is that possible its in the trunk of the car do you need to be two persons and put one in the trunk before you let the car go to sleep?
Something is fishy with the procedure
Does anyone have some insight?
- x 1929
- x 6955
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.trollkarlen wrote: 01 Aug 2024, 12:09 Oki, thanx for checking
PEUGEOT
9815469280
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
| A response to your question by a Forum Admin requiring parts or specific vehicle information requires you to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum. |
