ESP/ASR System Fault
Mad Jack
x 3
Unread post by Mad Jack »
Hello,
I have a 2015 C4 Picasso 1.6 diesel, with an electronic gearbox.
Over the last couple of days, the message ‘ ESP/ASR System Fault have the vehicle repaired’ has appeared on my dash, the vehicle will then only crawl along at 20mph. I turn the car off, wait a couple of minutes and start it again, and it then drives fine, but the check engine light stays on.
Is this something I can fix myself or is it a main dealer visit?
Thanks so much for any help or advice.
x 6948
Re: ESP/ASR System Fault
It needs a proper diagnostic done and then provide all the fault codes with along the VIN for further help. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
x 1496
The first suspect on these for any speed sensor related faults is the wiring to the rear ABS sensors that rubs through on the conduit. It's not too hard to check and worth a look if you don't have access to fault reading equipment. The problem area may appear small however!
RichardW wrote: 17 Mar 2024, 21:32
RichardW wrote: 16 Mar 2024, 20:50 Picasso light show....so I'm expecting a rear sensor fault and a corroded cable...
And so it was. Computer pointed to the LH rear sensor, and with the wire popped out the conduit, I spotted this
Seemed like it was just rubbed through and touching so I taped it up and put it back together....to be greeted with a permanent fault🤔. Stripped it back out, and put a connector in, wire just fell apart, I think I had scraped out all the copper! Trip out this afternoon and no warnings 😀 needs new rear pads though....
Mad Jack
x 3
GiveMeABreak wrote: 30 Jul 2024, 13:06 It needs a proper diagnostic done and then provide all the fault codes with along the VIN for further help. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Thanks, I found an independant Citroen garage who can read the codes, I’ll get it scanned and see what it says.
Thanks so much.
Mad Jack
x 3
RichardW wrote: 30 Jul 2024, 16:52 The first suspect on these for any speed sensor related faults is the wiring to the rear ABS sensors that rubs through on the conduit. It's not too hard to check and worth a look if you don't have access to fault reading equipment. The problem area may appear small however!
Thanks so much, I can definately check them, that would be a result if it is that 😊 Thanks again
