I have a fault on the car P2670. Unable to clear error. I did a little research. When I unplug the 5 pin connector. From this part (Delphi 96 600 305 80) (I don't know what this is called). Then I can erase the mistake. Only then does a new error P1471 appear (I think it's logical). Can someone give some advice, opinion, what is wrong, what to replace?
Car Citroen c5 x7 1.6hdi 2009
Thanks in advance
Citroen c5 Error P2670
PaulC5
- x 704
Re: Citroen c5 Error P2670
A search on your part no. comes back as the throttle body https://www.ebay.co.uk/itm/156038503523
Have a look at this topic with the same fault code P2670 where it was suggested to check the battery, earth points and unplugging various sensors (but you might have found the faulty one when you unplugged the throttle body). Unfortunately the OP did not come back to say what if anything was the fix, despite saying he would. viewtopic.php?t=61652&start=15
P1471 effectively is saying you have the throttle body unplugged viewtopic.php?t=74042
Nikolica15
Thanks for the answer. I think that sensor is with 5 pins (throttle body). But I don't know how to test it, and I don't have a wiring diagram.
Nikolica15
Can someone give me the wiring diagram for that 5 pin part, and how to test ??
- x 6948
I'll need your VIN for a diagram.
I'm assuming you have a 1.6 DV6TED4 110, but I'll know for sure when I have your VIN.
As for the P2670 fault, this indicates the 5v supply to many of the sensors is too low. The engine ECU supplies the 5V power to many of these sensors, so it is a shared supply, as you can see from the fault analysis below, so can affect multiple sensors. It's therefore important to get to the supply issue rather than the individual sensors.
I would be looking at the engine ECU pins, making sure they are not loose or detached and plugged into the connectors correctly, or for a break in the harness supply wiring.
When I have your VIN, I can provide a specific diagram relative to this engine management system for you to help trace the wires.
| Fault Code: | P2670 |
| Description of Fault: | Supply of sensors 5 Volts n°2: Voltage too low. The voltage supply to the sensors is lower than 4,7 V for more than 150 milliseconds (Air conditioning pressure; Engine speed camshaft). |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: | - |
| Symptoms: |
| Suspect Areas: |
Nikolica15
Thanks for your reply.
VIN is : VF7**************[VIN obfuscated, can be read by forum staff]
Thanks for the advice, I'll try to check the connectors and cables on the computer. Is it possible that this part is defective (Delphi 96 600 305 80(throttle body valve )), so that it draws voltage?
And how could I check if that part is working properly?
- x 6948
Here you go this is the Engine EC for your vehicle.
With the exception of the wiring codes, most of the component codes are indexed here:
PSA Electrical Diagrams - Wiring & Symbols Codes Index
Nikolica15
Thank you.
If I may, one more question and that's it. I can't find the description of the component, it's not listed. (1361 and 1362). And do you maybe have a wiring diagram for the throttle body valve (6 pins, but 5 wire). Here's a picture.
Thanks in advance.
Thanks in advance.
- x 6948
1361: turbocharged air heater electrovalve 1
1362: turbocharged air heater electrovalve 2
That looks like the air mixer unit. The 2 components above (1361 & 1362) are for the air metering device.
Nikolica15
Can someone give me a description of the faults for my car. Errors: P1351, P0490, P1459, P0409. Thanks in advance
- x 6948
P1351 concerns the glow plugs / or the glow plug relay (relay supplied but glow plugs not supplied)
Her are the others:
Her are the others:
| Fault Code: | P0490 |
| Description of Fault: | Position indicator signal of the EGR valve: Positive loop gap. Positive difference of 30% % between the exhaust gas recirculation valve position reference value and the position measured (For 10 seconds). |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P1459 |
| Description of Fault: | Position indicator signal of the EGR valve: Valve jammed open while driving. EGR valve jammed shut while driving for 5 seconds. Cleaning forced by the engine ECU. |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0409 |
| Description of Fault: | Electric EGR valve position copy signal: Valve sticking during the initialisation. Valve sticking for 8 seconds during the initialisation of the powerlatch (between switch off using the key and the ECU going to sleep). Conditions of activation of the diagnostics The following conditions have to be met: - Consult the associated contexts for the Pcode forwarding conditions - The engine coolant temperature should be between 10 and 100 ° C - The battery voltage has to be between 10 and 15 volts |
| Symptoms: |
| Suspect Areas: |
ianmcc
,,, yes this is the 'Doseur', or the 'EGR throttle Electrovalve' if you are using DiagBox.
It only has 5 pins and looks like this inside when the cap is prised off.
This device doesn't appear on the wiring diagram. Two of the pins are for the motor, the other three are for the 'position sensors' and are connected to the small circuit board.
The old style potentiometer type throttle body had 6 pins - 2 for the motor and 4 for the pots, power, earth and the x2 wipers. This has a 3 pin 'non-contact' way of reporting 2 valve positions - I don't know how it works. I have not had P2670 so can't assist with this. My issue is with the car always in limp mode because the 'copy position sensor' - which is one of these two sensors - is incorrect (P0490).
Hope you get sorted ............, Ian
