Hi all I’m after some help again I have 2 codes showing on my car and wondering if anybody can help it’s a 2008 2.0hdi c4 Picasso the 2 codes are
p1471 citroen electrodrive fan 1 operational failure dpf regen incomplete
P1351 ignition coil control circuit high voltage
I think the second one maybe glow plug related but the first when I google it comes up with egr not what the description says any help would be much appreciated thanks
P1471 code help needed
- x 6946
Re: P1471 code help needed
| Fault Code: | P1471 |
| Description of Fault: | Throttle housing electrovalve control (EGR)(Principal air meter): Throttle open. Detection of an open circuit (For 100 ms). Conditions of activation of the diagnostics Battery voltage more than 7V EGR butterfly command between 10 and 95% |
| Conditions for Fault to clear: | Ignition on |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
shaun1983m
Thanks i might sound stupid here but does this mean it’s either a new egr valve or the wiring to it maybe
- x 6946
Not necessarily, I would be checking the MAF, and all electrical connections as mentioned above.
shaun1983m
Ahh I read it wrong thought air mixer was egr
Jay-Bruce
- x 280
P1471? I thought that was when the engine was trying to see who called it last?
shaun1983m
Hi again have replaced the maf now I’m getting more codes come up this bloody car is doing my head in any more help would be much appreciated the new codes are p1693 p1403 p1404 p0238 ThanksGiveMeABreak wrote: 22 Mar 2023, 12:33 Not necessarily, I would be checking the MAF, and all electrical connections as mentioned above.
- x 6946
| Fault Code: | P1693 |
| Description of Fault: | Controlled engine starting and stopping: Starting or stopping requests absent or not valid. Request for starting; Engine stopped: absent; Not valid: For 150 ms. |
| Downgrade Modes whilst Fault is active: | - |
| Symptoms: | - |
| Suspect Areas: |
| Fault Code: | P1403 |
| Description of Fault: | Additional heating relay control fault 1: Circuit to earth; Short circuit to positive; Open circuit; Actuator malfunction. Short circuit to earth or short circuit to positive or open circuit: Actuator malfunction (For at least 2 seconds). Conditions of activation of the diagnostics:
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P1404 |
| Description of Fault: | Additional heating 2 fault: Circuit to earth; Short circuit to positive; Open circuit; Actuator malfunction. Description of the diagnostics: Short circuit to earth or short circuit to positive or open circuit: Actuator malfunction (For at least 2 seconds). Conditions of activation of the diagnostics:
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0238 |
| Description of Fault: | Turbocharger pressure signal: Short circuit to positive. Voltage of turbo air pressure signal higher than 4,80 V (Turbo pressure greater than 2530 mbar) ; For 2,5 s or 125 engine revs. |
| Symptoms: |
| Suspect Areas: |
shaun1983m
Thanks looks like a bloody lot have you any idea on where to start looks like it could be very expensive at the garage
