Eolys?
x 6945
Re: Eolys?
Sebudex wrote: 02 Jul 2024, 18:31 Hello everyone I read forum long time but that's my first post after registration few minutes ago . I currently get warning about low level of DPF fluid and service writing on dashboard. I already bought 3 litre additive fluid kit on eBay but still not topped up because my nearby garages have no time or willingness to connect diagnostic tool to made necessary things. So I have 2 questions:
1 - is any chance make sure what pat fluid is need just after registration number?
2 - what tool / software I will need to update fluid level ?
Car - Citroen C5 2.0 HDi 16v vtr+ navi 2010
I'm apologize for my English as it's not my 1 language.
1) No, I need your VIN not the reg number to determine the correct type of additive. You should of asked this question first before buying any additive as it must be the exact correct type and some additives cannot be mixed together or you will damage the pump dosing system and that will be more expense.
2) You need a professional level diagnostic tool with Lexia / Diagbox, laptop etc. If you don't have this or don't know what your doing, just get the dealer to fill it and reset for you - often will be cheaper in the long run without issues.
k4n3
Re: Eolys?
Unread post by k4n3 »
Hello Folks,
how could I know is my car requires Eolys, and if yes which type exactly?
Thanks so much in advance!
x 6945
Re: Eolys?
Hi
You don't have an Eolys additive tank on this vehicle (like me). The particle filter uses natural regeneration when it reaches the required temperature. So no need to worry about this.
Sebudex
Re: Eolys?
Unread post by Sebudex »
GiveMeABreak wrote: 03 Jul 2024, 13:58
Thanks for answering.
That what I was thinking I will need vin not reg but I bought cheap in offer from eBay https://www.ebay.co.uk/itm/284644319246
seller ask only for reg number , so if will be wrong I will sent back.
vin number VF7**************[VIN obfuscated, can be read by forum staff]
I bought that way because I had back injury and I couldn't look under car to check colour of connection. 🤪
About digabox any chance help with one kit I will need because on eBay is that many prices and kits I don't know which one to order.
x 6945
Re: Eolys?
I need the full vin or the last 8. What you have provided is useless as it doesn't provide the specific info I require. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
k4n3
Re: Eolys?
GiveMeABreak wrote: 05 Jul 2024, 15:22 Hi
Hi Marc,
First of all - thanks for answer. This is good and bad news for me together :D
May I share my problem here? After quick search I didn't find appropriate topic. Ofc feel free to move it to a better location.
OBD scanner shows P242F(97) alarm, and FAP app shows FAP life left is 0 (together with very short regen intervals of ~300km).
Actual mileage is 170,200 km (I am in Germany).
All the rest is Ok - dynamic, fuel consumption, FAP differential pressure (as can be seen on screenshot), as well as cars cockpit doesn't indicate any alarm.
Well, ok, I am not sure about Cinder count in FAP = 37%, is it much?
I thought refilling Eolys helps me, but obviously I don't have it.
Should I worry about replacement of DPF now? Or, what should I worry about now? :D
Best regards, Ted
x 6945
Re: Eolys?
Yes, from that mileage your DPF is likely nearing / reached end of service life. The code means the filter has reached the threshold of it's service life, so time to think about either having the DPF professionally deep-cleaned or replaced with a new one and then telling it you have replaced int he repair section.
k4n3
Re: Eolys?
GiveMeABreak wrote: 05 Jul 2024, 18:39 Yes, from that mileage your DPF is likely nearing / reached end of service life. The code means the filter has reached the threshold of it's service life, so time to think about either having the DPF professionally deep-cleaned or replaced with a new one and then telling it you have replaced int he repair section.
May I know, what happened if I ignore this for a while?
I mean, it's looks to time kind of "statistical" interval from Citroen, when DPF must to be replaced.
I am thinking to monitor diff pressure, but the question is - can the car forcibly gone to limp mode just becasue of "calculated lifetime" is finished?
Best regards, Ted
x 6945
Re: Eolys?
The system is fitted with differential pressure sensors that act as a safety device. You may need to go for a 'hard drive' on the autobahn to get the engine gasses nice and hot and give the DPF a good opportunity to regenerate the filter. But you have to realise that engine debris and ash (that can't be burned off during regeneration) will remain and gradually block the filter. If the filter gets anywhere from 70% and upwards blocked, then it may become impossible to regenerate and will need replacing.
You will eventually get power limitation (limp mode) initiated by the engine ECU if the filter remains blocked as this will cause back pressure and engine problems.
k4n3
Re: Eolys?
GiveMeABreak wrote: 05 Jul 2024, 19:13 The system is fitted with differential pressure sensors that act as a safety device. You may need to go for a 'hard drive' on the autobahn to get the engine gasses nice and hot and give the DPF a good opportunity to regenerate the filter. But you have to realise that engine debris and ash (that can't be burned off during regeneration) will remain and gradually block the filter. If the filter gets anywhere from 70% and upwards blocked, then it may become impossible to regenerate and will need replacing.
I've got it, thanks so much!
One last question - is "Cinder count in FAP" in FAP app shows the blockage of the filter? It's currently 37%.
I am wondering how can it be calculated by ECU...
Best regards, Ted
Sebudex
Re: Eolys?
GiveMeABreak wrote: 05 Jul 2024, 17:11 I need the full vin or the last 8. What you have provided is useless as it doesn't provide the specific info I require. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Apologize my mistake i didn't notice I was copied just first part
Vin VF7**************[VIN obfuscated, can be read by forum staff]
x 6945
Re: Eolys?
@Sebudex: Ok, so you need Eolys EXTEND, which is specific for the C5 X7 with this build date, NOT Powerflex.
Sebudex
Re: Eolys?
GiveMeABreak wrote: 06 Jul 2024, 11:47 @Sebudex: Ok, so you need Eolys EXTEND, which is specific for the C5 X7 with this build date, NOT Powerflex.
Thank you so much Marc. I ordered 3L from
https://www.eurocarcare.net/oil-and-flu ... itres.html
I get last one and that hopefully will be that what I need.
So it's mean my C5 is X7 ? Any suggestion about diagnostic kit I'm confused with Lexia or Digabox kits models and difference between them.
One more time Thank you Marc , tomorrow probably I will be pouring that fluid what I bought from eBay and it's looks it's Powerflex 😳 thanks for saving my car 😬
x 6945
Re: Eolys?
That's fine.
Your C5 is the MK III, PSA code name X7.
We call the first generation C5 MK I (2001 to Mid 2004)
We call the C5 MK II the Facelift version (2004 to 2007)
We refer to the 2008 -> the MK III (X7).
GORAX
x 14
Re: Eolys?
Unread post by GORAX »
How do I find out if my car has it too this Eolys?
GOOGLE TRANSLATE
