2020 C5 Aircross Automatic 1.2L PureTech
BenEadir
Unread post by BenEadir »
Hi all,
Real newbie question here. I recently bought a 2020 C5 Aircross 1.2L Automatic and I just want to know what oil I need to buy for topping up? I tried looking online but get different recommendations, either 0W30 grade or 0W20 grade.
Can someone please confirm what the correct oil specification for the 1.2L petrol engine is and any particular brand which users recommend?
Thanks.
x 6950
Re: 2020 C5 Aircross Automatic 1.2L PureTech
You'll need to pop your VIN up as specifications are engine and engine variant specific. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff. Further, PSA changed the oil specs early this year, so I'll check the current official grade and spec. for you.
BenEadir
Thanks @GiveMeABreak,
My VIN # is VR7**************[VIN obfuscated, can be read by forum staff]
x 6950
In all cases the oil has been changed to 0W20 for the grade, but please note that the specifications (B71 2010) should also be followed as these have a wet timing belt!
EM: 0W20 B71 2010
0W20 B71 2010 (C5)
The officially recommended oil is therefore:
QUARTZ INEO XTRA FIRST 0W20
BenEadir
Thanks @GiveMeABreak, I appreciate it.
So it looks like this is my best option? https://lubricants.catalog.totalenergie ... irst-0w-20
I can see from the service the garage I purchased the car from did just before I purchased it that they changed the wet timing belt (car had 95,000 KM's on it) which is a good thing but they used WOLF OFFICIALTECH
0W30 which may have been the originally specified oil for the car?
Either way, if I'm topping up the oil before my next service should I top up the existing 0W30 oil with 0W20 or should I keep topping up with some 0W30 and then do a full oil change to 0W20 at the next service?
x 6950
Just change it at your next oil change - do a drain and refill.
BG18YCE
Re: 2023 C5 Aircross Automatic 1.2L PureTech
Unread post by BG18YCE »
Hi, Does anyone know the correct oil for a C5 1.2L
2023 engine. Thanks
PaulC5
x 718
Unread post by PaulC5 »
You should have been given a service schedule sheet of paper when the car was new which notes the correct oil but if you do not have this you can get one from a Citroen dealer without charge and even then it is worth while getting an up to date one since oil specs change. They should put the oil type used when serviced on the receipt as well. This topic will also help viewtopic.php?t=75919
For a car still under warranty I would keep having the oil changed by the dealer.
BG18YCE
Thanks for the info 👍
x 6950
BG18YCE wrote: 31 Jan 2025, 15:14 Hi, Does anyone know the correct oil for a C5 1.2L
2023 engine. Thanks
Do not rely on my guide - refer to the introduction - I am no longer updating that document because of the frequent changes to oils specs. If you want to know the current correct grade for your vehicle, post up your VIN and I will be able to provide the official Citroen grade currently used for your exact engine. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
BG18YCE
Hi, Thank you for your reply...
My vin is VR7**************[VIN obfuscated, can be read by forum staff]
Thanks Gary
BenEadir
@GiveMeABreak can you please confirm the correct oil for my C5 Aircross Vin # VR7**************[VIN obfuscated, can be read by forum staff]
Thanks, I appreciate it.
x 6950
BG18YCE wrote: 01 Feb 2025, 13:52 Hi, Thank you for your reply...
Thanks Gary
Current Oil is:
Grade: 05W30, Citroen Specification: FPW9.55535/03
x 6950
BenEadir wrote: 01 Feb 2025, 16:08 @GiveMeABreak can you please confirm the correct oil for my C5 Aircross Vin # VR7**************[VIN obfuscated, can be read by forum staff]
As above:
BG18YCE
Hi, Could you supply a copy of my service schedule
I have just bought the car and am struggling to get any info about services etc.
My Vin is VR7**************[VIN obfuscated, can be read by forum staff]
Any help much appreciated Gary
