Information on plastic covering underneath engine and bumper
Martynelius
I have a Citroen C5 Estate 2.0 HDi 2002 VIN: VF7**************[VIN obfuscated, can be read by forum staff] that has missing/damaged plastic covering underneath the engine and underneath the front bumper that I would like to fix. The local car wrecker has two Citroen C5 Type 2 (model year unknown) and would like to know if the covering from these would fit my Type 1 model. If someone has pictures/diagrams/documentation of these to compare would be most appreciated.
- x 6957
Re: Information on plastic covering underneath engine and bumper
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
| A response to your question by a Forum Admin requiring parts or specific vehicle information requires you to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum. |
- x 6957
Thanks for your Forum Donation Martyn. From the part numbers below, you can at least search the internet for copy parts or original second-hand parts.
(Ignore the image of the Saloon, these are correct parts for the estate version).
Note: NFP = No Longer Available From Citroen
(1) Soundproofing Under Engine and Gearbox, part: 7013N9 (NFP)
Autodoc have an equivalent here (https://www.autodoc.co.uk/car-parts/oem/7013n9)
(2) Air Deflector Under Engine:
Left, part: 7013T3 (NFP)
Right, part: 7013T2, £167.57
(3) Air Deflector Under Engine (Left), part: 7013K4 (NFP).
If you need any clip part numbers, please let me know.
- x 2005
I looked at this for my Mk2.....I found a Mk1 and it did not fit at the front
