PART # FOR XANTIA LHM RESERVOIR / TANK
citroenroen
Unread post by citroenroen »
I need to replace my warped LHM reservoir tank.
What is the part number ?
Any suggestions what vendor may have it in stock?
Thank you
x 6947
Re: PART # FOR XANTIA LHM RESERVOIR / TANK
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
citroenroen
Thanks for your reply
"Sorry, we weren't able to complete your payment at this time. "
PAYPAL is blocking my donation .
Any other suggestions ?
x 1472
Unread post by xantia_v6 »
I don't know if any new LHM tanks are available, but it is rare to find a used one which has not sagged due the pressure of the spring clip.
This Turkish company has made a kit to fix a warped tank.
https://www.drxantia.com/index.php/en/ ... eg-detail
x 6947
citroenroen wrote: 13 May 2024, 00:40 Thanks for your reply
Please refer to this article:
https://www.paypal.com/us/cshelp/articl ... ed-help419
thorter
x 44
Unread post by thorter »
Not sure if I posted this previously. I fixed a sagging Xantia tank using a short length of 110mm plumbing waste pipe. With the tank empty, measure and work out the height required. Cut pipe to this length, then also cut it through along the length. It can now be squeezed down to go inside tank, then opened out a bit to seat on the base, and round the aperture, also resulting in a big enough route for a free flow of fluid. Sorry dimensions long since forgotten.
x 1472
thorter wrote: 13 May 2024, 10:07 Not sure if I posted this previously. I fixed a sagging Xantia tank using a short length of 110mm plumbing waste pipe. With the tank empty, measure and work out the height required. Cut pipe to this length, then also cut it through along the length. It can now be squeezed down to go inside tank, then opened out a bit to seat on the base, and round the aperture, also resulting in a big enough route for a free flow of fluid. Sorry dimensions long since forgotten.
I took inspiration and did the same. By my measurements, 100 mm soil pipe should be used, the hole in the top of the tank is about 90 mm diameter.
The correct length for the spacer (to get the top of the tank level) was 152 mm. There are three moulded ribs in the underside of the top of the tank which get in the way, so I roughly cut 3 notches at 120° in the top of the spacer to clear those. I also drilled a few holes to allow some flow of LHM.
Warming the top of the tank with a hot air gun made it easier to get the bend out of the tank to fit the new spacer.
Nick Orfanidis
x 4
Unread post by Nick Orfanidis »
Greetings.
First of all, I must say that the tube idea is very smart. The only thing that I'm sorry is, I didn't think it earlier....
Now, let me make a correction. The correct length of the 100mm tube , is 152mm (not 252mm). Also, for the right fitting of the tube I had to cut a side piece of the internal plastic "wall".
So, this my "version" of your idea...
thorter
x 44
Excellent. After doing the original mod I had no further trouble with LHM leakage, so I hope everyone has the same success.
