C5 X7 2012 always blows air
Karolis Vansevicius
Unread post by Karolis Vansevicius »
Hello,
Yesterday happened strange thing. Air flows to the cabin all the time, even when climate control is turned off.
Tried to disconnect battery, reconnect air blow fuse - nothing helps.
Diagnostics shows no trouble codes.
Citroen C5 x7 Tourer 2012 year.
x 6955
Re: C5 X7 2012 always blows air
It's probably the Blower Motor Control Module. If it's all or nothing then the module likely needs replacing.
Karolis Vansevicius
Maybe do you know it's OEM part number? :/
x 6955
See my post here:
viewtopic.php?p=499891#p499891
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Karolis Vansevicius
Just replaced with a new one https://www.eoltas.lt/lt-lt/products/AI ... uliatorius .
Problem still exists :(
x 6955
Never heard of that brand before, so can't comment. Personally, I would only fit a decent brand like BEHR, Valeo or Fibi Bilstein, as other brands have been known to just not work.
Check all the wiring around the module for signs of scorching or burning.
Karolis Vansevicius
Just replaced with original one from working auto - still the same. Also wires are a little bit hot.
Lexia shows that climate control module is OK
Karolis Vansevicius
