Stiff suspension after spheres regassing - C5 X7
GolfMk1Vr6
Hi!
1 month ago i have regassed 6 spheres on my Citroen C5 X7 Tourer, 2.0 HDI 2012.
On the very first ride i have noticed that the suspension became quite stiff, it wasn't as soft as before.
Thinking that one sphere didn't hold the pressure, today i have rechecked the front ones and the pressure is fine.
The suspension level is correct, made through Lexia and height sensor adjustment, LDS fluid is new, no height sensor errors/ problems.
Before regassing the car had a very nice ride feeling, i couldn't feel any road holes, now it feels like a sports car, i can feel every imperfection on the road.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
- x 6945
Re: Stiff suspension after spheres regassing - C5 X7
Did you bleed the system afterwards? Very likely you have air in the system. Was there a reason why you didn't gas the 7th spere?, and were they all to the specific correct pressures required for each of the spheres?
GolfMk1Vr6
Hi!
When i regassed the spheres i think that my mechanic bleeded the system through Lexia. After LDS changing the bleed probably wasn't done.
The 7th sphere wasn't regassed because i was told that it's very difficult to reach it.
All spheres removed from the car had between 30 and 40 bars. They were filled with 50+ bars.
Kees
- x 148
It's not difficult to remove the front stiffness sphere!
You need to remove the left drive shaft and beneath the subframe the 6mm bolt with hold the airco tube.
And then with a long chisel you can hammer it loose.
I did this already a few times with different car's
Greetings,
Kees.
Greetings,
Kees.
OnlinePaul-R
- x 1940
How usable for regassing does that leave the sphere?
- x 1460
Each sphere has a specific design pressure. Regassing to some unspecified pressure of 50+ bars will not.result in correct suspension performance.GolfMk1Vr6 wrote: 24 Apr 2024, 20:51
GolfMk1Vr6
For my car, these are the required pressures for each sphere:xantia_v6 wrote: 25 Apr 2024, 08:55Each sphere has a specific design pressure. Regassing to some unspecified pressure of 50+ bars will not.result in correct suspension performance.GolfMk1Vr6 wrote: 24 Apr 2024, 20:51
- x 6945
There's you problem then! You can't bleed the system via Lexia / Diagbox. That is only for fully depressurising the hydraulic system. It does not bleed it, so you probably have multiple air locks in the hydraulic system.GolfMk1Vr6 wrote: 24 Apr 2024, 20:51 Hi!
Follow this: make sure the vehicle is on level ground.
1. LDS cap off.
2. Start the engine.
3. Setting suspension in high position.
4. Setting suspension in low position.
5. Turn the steering wheel slowly lock to lock (do not hold the steering wheel at the lock limit!).
6. Return steering wheel to centre position.
7. Engine off.
8. Wait for all the bubbles to disappear.
9. Check fluid is between the 'a' & 'b' marks in the picture below.
10 Repeat as necessary.
11. Raise vehicle to normal height.
12. LDS cap back on.
Kees
- x 148
Marc, point #9 is only, when the car is in the lowest position with the help of the diagbox.
Otherwise if you put the car in the low position, then you should see just a little LDS at the bottom.
Greetings,
Kees.
Greetings,
Kees.
- x 6945
Yes, I know that Kees, but that is what we go by as not everyone has access to the diagnostic tools to fully depressurise the system or are not confident to manually depressurise the axles. This is perfectly normal as the tank has capacity for the little extra fluid.
GolfMk1Vr6
Yesterday the LDS was replaced and i also cleaned the hydraulic pump, my mechanic added 3 liters of LDS. After that, no specific bleeding operation was done, i will try it today using your method and come back with a feedback
Thank you!
- x 6945
This is the correct way to bleed it officially, so must be done or you'll never get it right. You may need to turn the steering wheel (slowly) several times to get the air circulation and out at point (5). You will get some 'fizz' at the top of the tank. Just let these air bubbles dissipate and repeat the whole procedure a few times, then go for a drive and see how it is.
Assuming you've listened top all the advice above regarding the correct sphere pressures of course (pop your VIN up and I'll check these are correct for your vehicle if you like).
GolfMk1Vr6
I took the car today and before doing the bleeding procedure the car seemed to be a little bit softer than yesterday. I did the bleeding and it seemed 10% better but still quite stiff/ harsh.
I couldn't see the LDS level between A and B because i don't have diagbox, as @Kees said i could see just a little bit of LDS but i couldn't see if it has any bubbles.
I will check the behaviour in the next couple days, i'm not driving the car that much.
Even if the front spheres hold the pressure well in 1 month after regassing, is there any chance of a sphere that is not holding the pressure and releases gas slowly in the LDS so the overall feeling is stiffer?
Or maybe the hydraulic pump/ steering rack may add air to the circuit?
Thanks for helping me
Kees
- x 148
I think, that you have to change/regasse the center sphere. Because this one is the one with provide the softmode, and also you have to look at the system completely.
If you decide to regass this one,it's no problem to put it on 75 bar.
Greetings,
Kees.
Greetings,
Kees.
GolfMk1Vr6
The only problem i had with the suspension was the rear height sensor rod that was rusted, the hydraulic pump was working permanently on the last height position without finalising it.
The mechanic cleaned the rod, installed it back, did the level and now it goes up fine.
Might be a problem with the sensor itself?
