Injection Diagram
Sponk
- (Donor 2026)
Injection Diagram
Diagram also in this thread? Is it possible, when you have access next time, to get information about the ECU connections for this one VF3**************[VIN obfuscated, can be read by forum staff] Thank you
Reason: Moved out of parts thread.
- x 6956
Re: Injection Diagram
You didn't specify which ECU. Diagrams are system-specific so we need to know the specific system, like, ABS / ESP, Injection, Locking, Gearbox etc.
I'm assuming you require the engine ECU, so...
With the exception of the wiring codes, most of the component codes are indexed here:
PSA Electrical Diagrams - Wiring & Symbols Codes Index
Sponk
- (Donor 2026)
Sorry, I didn't know, but EDC17C10
Not much more information for now.
- x 6956
That's OK, I don't need the injection type - that is automatic based on your vehicle VIN data - I was just trying to advise you that ECU diagrams are separate for each major system, so I guessed if it's the injection system you required, then what is what I have put above already for you.
Sponk
- (Donor 2026)
It was only to see the possibility of changing it, also has the associated BSI. Looking for overview of the connections appropriate for the model.
But now that we're writing, I want to hear from you why some numbers are only displayed as, for example, 10- -?
- x 6956
Anything with a ------ line around it means it is optional equipment and may not be installed on your vehicle.
Basically as I think I mentioned the BSI, Engine ECU and Transponders are matched sets. If replacing any one of these parts, they must be either new and configured and paired online with the correct diagnostics, or virginised if second hand used and then paired and configured as mentioned.
- x 1342
I think that it is more correct that those are off-page connectors to other parts of the electrical system, and the 2 digit code indicates which system is referenced. For example here, 10-- is the charging system, 15-- is the cooling system, 16-- is the transmission etc.GiveMeABreak wrote: 18 Apr 2024, 17:06 Anything with a ------ line around it means it is optional equipment and may not be installed on your vehicle.
Sponk
- (Donor 2026)
What about the numbers that are not on the list, for example 1357, Is it an error in the listing?xantia_v6 wrote: 18 Apr 2024, 21:22I think that it is more correct that those are off-page connectors to other parts of the electrical system, and the 2 digit code indicates which system is referenced. For example here, 10-- is the charging system, 15-- is the cooling system, 16-- is the transmission etc.GiveMeABreak wrote: 18 Apr 2024, 17:06 Anything with a ------ line around it means it is optional equipment and may not be installed on your vehicle.
- x 6956
You need to look at the info I provided on the electrical diagrams, specifically here:
PSA Electrical Diagrams - Reading The Schematic Diagrams
Look at H, I & J on the example diagram.
'H' & 'I' are what Mike is referring to and 'J' means it's for optional equipment. So in your example yes, it's a link to another system. I should of paid more attention.
As for 1357, this is the proportional oxygen sensor.
I update the list as and when I have time and if people notify me, as it takes a while to update. The original list is quite old, so won't contain more modern systems and wiring, but I have updated this one now with the code you mentioned.
Sponk
- (Donor 2026)
Knows how to interpret a chart and also knows what 1357 was. Was only wondering if it was a mistake that they weren't mentioned on the list, but could also be PSA that didn't state it, they are good at keeping certain things “ secret”, but
From 3 different diagrams I have found these missing, 0004 , 1283, 13A3 (A must be an error), 1356, 1357, 1361, 1362, 1374, 1405, 1604, 7095. I myself find the missing information when comparing other diagrams, either via connection or wire no.
“Personal progress only. Extracted the keycode and started setting up the BSI so I only need to do a fine-setup when I plug it in. The EDC requires a bit more but should be good. Also got The BPGA, but missing the connection on it.”
- x 6956
13A3 is not an error. It is the inlet air temperature and pressure sensor.
That's why we use specific diagrams for each vehicle as different engines and engine management systems have different sensors and equipment.
Sponk
- (Donor 2026)
Whenever possible, if you also have over BSI
- x 6956
There is not diagram for the BSI - only the systems attached to it. They do not supply internal information for the BSI. This is the only info regarding the fusing:
