Good afternoon all
Trying to source a suspension pump and bhi unit. I've been told the 2.7 engine has a different pump to the smaller engines. Could anybody confirm that for me, and ideally confirm the part number I need as the label has gone off the original. Vin VF7**************[VIN obfuscated, can be read by forum staff].
I'd be most grateful for any help
C5 x7 2.7 suspension pump
- x 6950
Re: C5 x7 2.7 suspension pump
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
| A response to your question by a Forum Admin requiring parts or specific vehicle information requires you to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum. |
Kees
- x 150
As far as i know, this is also for my car, but i think, that the bsi is different.
The service box mentioned 2 types, one for smooth road and one for bumpy roads.
So i think, the parameters in the bsi are different.
Greetings,
Kees.
Greetings,
Kees.
- x 6950
The parts are also different because with a V6 the BHI suspension computer has different functions as it works with the additional CSS suspension computer found on V6 models.
Kees
- x 150
@marc:
You are right, but even so, other types C5 X7 have 2 types of the pump and always the description that i mentioned.
Greetings,
Kees.
Greetings,
Kees.
- x 6950
I'm just pointing out that V6 and a version of the 2.2 X7s are specifically different. Other 4 cylinder vehicles excluding the 2.2 I mentioned may be re-configured to get around this, but the BHI / CSS software for V6 models and possibly the 2.2 is operationally and functionally different.
@Chris_reade10: Thanks for your Forum donation, check back here ion a few minutes for the part numbers you need.
- x 6950
Chris, details below:Chris_reade10 wrote: 11 Apr 2024, 11:53 Good afternoon all
These parts are specifically for your C5 X7 2.7
(1) Brand New Original Suspension Hydraulic Block (requires configuration), part: 5277K5, £1961.84
Brand New pre-configured Suspension Hydraulic Block, part: 5277K6 (No Longer Available)
Standard Exchange Block (Requires configuration), part: 1680916580, £1258.46
Prices as of today direct from Citroen.
At least you have the part numbers on which to search for now if looking for after-market.
