Reconditioned gearbox
Webbgray2swindon
Unread post by Webbgray2swindon »
We had a reconditioned gearbox second gear crunching sent back as 4th gear started crunching now all been done but have a small leak which when we took back to the garage they said water was getting into the gear box due to the gully on the windscreen was not diverting correctly so they replaced and put silicone etc to divert around the windscreen. We have had no rain and still a link which is definitely the transmission fluid leaking in the floor .
We are going to go back but this is where we have found the leak what is this part called 🤷???
x 6947
Re: Reconditioned gearbox
Best to pop your VIN up as you haven't stated the model, year, engine or gearbox type, but initially, looks to be the gear selection control cable, but there should be 2 ends and I can only see the one in your pictures. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Webbgray2swindon
Peugeot Boxer 270 TD SWB
1905cc Motorhome
After the reconditioned gear box was installed we ended up with a leak which we never had before and this is where it is coming from
x 1056
Unread post by wheeler »
That’s the speedometer drive output for the speedo cable.
x 1496
Pretty sure that's the speedo drive - is it on the side of the diff above the RH drive shaft?
x 6947
Yes, thanks chaps, so looks like the seal has gone. The official name for this is the 'Tachometer Control Seal' which is what you originally wanted, but if you find you need an official part number or part diagram please see below:
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below:
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Webbgray2swindon
Thanks everyone
