PSA NAC RCC Updates
marios
Re: PSA NAC RCC Updates
Hi Marc!
- x 6948
I've merged your posts into the PSA NAC RCC Update thread.
Your vehicle was actually built on 2nd November 2017.
From the information I have there is no 'Mirror Link' showing which was the older version prior to Android Auto. My feeling is if Mirror Link was not available then that may indicate neither was CarPlay compatibility either - but I can't be 100%.
In either case, your Firmware is quite a few versions out of date.
This is the latest Firmware and the Licence File you will need to install the Firmware:
Firmware V 1_076_16.1B116.4
Marios Licence File
Instructions for Updating NAC or RCC Firmware, Maps & Licences
Please note that the PSA servers are intermittently working as of this post, so this may cause some disruption to downloads. They may be undertaking some maintenance
Marios Licence File
marios
Thanks Marc.
Later today i will install new firmware version 1_076_16.1B116.4
MarioS
MarioS
Raizel
Hello, can you please help me too, even though I am from the Turkey? Thanks
My VIN number is VF7**************[VIN obfuscated, can be read by forum staff]
- x 6948
No problem...
RCC Firmware Version 6_0422_23.3I37.1
Raizel Licence File
Raizel Licence File
edo2909
Hi from Split, Croatia.
I downloaded the update file 6_0422_23.3137.1 from your post but need a licence.
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Thanks a lot
Edo
- x 6948
edo2909
Thanks Marc, hope it will work.
Martin3322
I am having the same issues with the Citroen Update App
I have a 2023 e-C4 and I can download maps to a USB pen no prob but when i try to download software (44.07.05.22_NAC-r0) I get an error
An error occurred while retrieving update data
VIN VR7**************[VIN obfuscated, can be read by forum staff]
ales ciuha
Hi,
could I get update firmware for my Berlingo.
Thank you
Thank you
- x 6948
It won't accept the update without a licence file, as you don't have on-board WiFi, so it cannot verify the update as being acceptable or compatible. If installing manually, you will need to read the instructions for using the licence file after you have prepared the USB correctly as per the instructions below after the link.
Firmware 44.07.05.22_NAC-r0
Martin3322 Licence File
- x 6948
6_0422_23.3I37.1 Firmwareales ciuha wrote: 28 Mar 2024, 11:26 Hi,
Thank you
ales ciuha Licence File
Martin3322
You are a legend . . . . Thank you very much !GiveMeABreak wrote: 28 Mar 2024, 11:27 It won't accept the update without a licence file, as you don't have on-board WiFi, so it cannot verify the update as being acceptable or compatible. If installing manually, you will need to read the instructions for using the licence file after you have prepared the USB correctly as per the instructions below after the link.
ales ciuha
Thank you very much.GiveMeABreak wrote: 28 Mar 2024, 11:316_0422_23.3I37.1 Firmwareales ciuha wrote: 28 Mar 2024, 11:26 Hi,
VIN VR7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Thank you
jose
Hello Marc
I downloaded the update file 21-08-87-32_NAC-r1 but need a licence.
(Screen screwed up on "Software loading on demande...")
