- x 6960
Always replace in pairs!
(1) rear Shock Absorber, part: 5206VY (may no longer be available), £75.86
Citroen Cheaper alternative, part: 1623316380, £51.07
(3) Flanged Bolt, part: 522312, £1.45
(10) Cage Nut, part: 8530KP, £3.12
(2) Flanged Bolt, part: 522316, £6.11
(4) Cage Nut, part: 522076, £3.73
dylan26__
- x 22
awesome thank you. Whilst we're on the topic of the rear suspension could you also give me the rear bushes for my car pls
- x 6960
What are you referring to - the rear hub bearings or the crossmember?
Hub Bearing Crossmember Mountings
dylan26__
- x 22
Cross member mountings please. Looks like the bushing can be replaced by itself too?GiveMeABreak wrote: 17 Mar 2024, 19:42 What are you referring to - the rear hub bearings or the crossmember?
Hub Bearing
- x 6960
(3) Crossmember Mountings, part: 5131H4, £47.95
(Ignore (1), as that is the complete crossmember, the mountings are (3))
Romtag
- x 8
Thanks Marc, I need to source an under bumper tray for the front of the car. When scouting eBay it shows two models. Could you work your magic for the part number ?
Mark
Owner of a 2013 308 SW
- x 6960
Assuming this is for the 308...
Let me know which item(s) you require.
508Allure
- x 5
Marc, could I get the part number for the eolys tank please:
kuhar
- x 3
Hi Marc,
Seems my Blower Motor Control Module is dead as per this thread viewtopic.php?t=63301 (fan won't stop blowing even when I switch off the car, a/c fans stuck on full), ODB is useless.
Should DENSO DRS21008 (citroen part 9821291880) be the right call?
Thanks!
Thanks!
- Marko
- x 6960
(16) Additive Reservoir, part: 9817154080, £269.64508Allure wrote: 19 Mar 2024, 16:30 Marc, could I get the part number for the eolys tank please:
- x 6960
Yes, that is the correct replacement part.kuhar wrote: 19 Mar 2024, 16:36 Hi Marc,
Thanks!
(3) Heater Motor Control Module, part: 9821291880, £185.27
508Allure
- x 5
GiveMeABreak wrote: 19 Mar 2024, 16:57Thank you very much.508Allure wrote: 19 Mar 2024, 16:30 Marc, could I get the part number for the eolys tank please:
VIN: VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Romtag
- x 8
Its the large plastic tray in the bottom left of image, yes the dadvan has gone to the scrapyard in the sky so that can be removed from your vin databaseGiveMeABreak wrote: 19 Mar 2024, 12:33 Assuming this is for the 308...
Mark
- x 6960
(2) Air Deflector Under Engine, part: 7013EF, £167.57
(70 Screw with washer, part: 692395, £1.46
(74) (MUL) CBLX RDL SCREW, Part: 6295N0 £0.78
dylan26__
- x 22
thought my top mount came with them but 3 & 4 i appear to also need. Feel i'm the most active person here on this threadGiveMeABreak wrote: 24 Feb 2024, 18:54The Springs are on a separate diagram:dylan26__ wrote: 24 Feb 2024, 17:12 Does there happen to be a diagram showing the whole strut aswell? Seen some struts with a ribbed bowl sort of thing below the top mount and some don't have this. Just wanna check mine does and replace it if needed. Cheers
Let me know item numbers
