x 6958
Hi John. Thanks for your Forum donation.
If it's item (4)
(4) Intake Filter Air Hose, part: 143437 (NFP - no longer available from Citroen).
If any other let me know the item number from the above.
John77vts
Unread post by John77vts »
Hi Marc
Yes thats the part thank you i will now try to source one online.
Kind regards
John
BVL
Unread post by BVL »
Hi Marc,
Could you please provide me the following oe numbers ?
1. Camshaft pulley bolt
2. Crankshaft timing belt pulley bolt
Also need to know the tightening torques for the same.
Thanks,
Bart
x 6958
I'm going out for an hour, let me know which items.
BVL
Hi Marc,
1st one is item no:10
2nd item is not in this exploded view, it is the bolt that fits the lower auxilery belt pulley to the Crankshaft.
And i need to know the tightening torques for the 2 items.
Thanks,
Bart
x 6958
(10) Camshaft Pulley Screw, part: 1682801980, £2.62
If it's (9), Crankshaft Pulley Screw, part: 1682800780, £8.65
BVL
Thanks Marc!
dylan26__
x 22
Unread post by dylan26__ »
Good morning! Could I have the part numbers for the front shock absorbers. I'm finding two different sizes of outer diameter for my car just need to make sure it's the right one
x 6958
(1) Front Damper
OEM Left, part: 5208H1, £88.48
OEM Right, part: 5208H2, £88.148
Cheaper Alternative Left, part: 1635532080, £81.04
Cheaper Alternative Right, part: 1635530880, £71.93
howardaskew
x 9
Unread post by howardaskew »
Citroen C5 X7 Estate 2012 VTR+ 1.6HDI 110 Wishbone Part nos.
Post by howardaskew » Sat Feb 24, 2024 1:27 pm
Good morning.
I am looking to change the wishbones on both sides of our 2012 C5 X7 Estate 1.6HDI VTR+ DV6C 110 VIN VF7**************[VIN obfuscated, can be read by forum staff]
Would I be correct in stating that the part numbers would be the same as our 2010 C5 X7 Saloon 2.0HDI VTR+163 VIN VF7**************[VIN obfuscated, can be read by forum staff]
I am reading that there are more than one type of wishbone, would I be correct that around 2010 they changed the part?
I am always grateful for any help received on this forum.
admiral51
x 391
Unread post by admiral51 »
admiral51 wrote: 21 Dec 2023, 15:26 Hi Marc,
Could i have a part number for an engine oil dipstick for Vin VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] please. The yellow plastic puller has broken off.
thanks
Colin
Hi Marc,
Cannot edit my post to get the Vin and make a new post but could you have a look for what i believe is the indicator/wiper/ air bag assembly for the above Vin.
Has got issues with no indicators/lights and said something about the air bag as well.
If you can post the steering wheel assembly much appreciated.
Colin
dylan26__
x 22
GiveMeABreak wrote: 22 Feb 2024, 11:28 Image
(1) Front Damper
Does there happen to be a diagram showing the whole strut aswell? Seen some struts with a ribbed bowl sort of thing below the top mount and some don't have this. Just wanna check mine does and replace it if needed. Cheers
x 6958
admiral51 wrote: 24 Feb 2024, 13:45
thanks
Colin
Hi Marc,
Colin
I need a VIN Colin - or tell me if it's the 2009 or 2010 X7 in your profile.
x 6958
dylan26__ wrote: 24 Feb 2024, 17:12 Does there happen to be a diagram showing the whole strut aswell? Seen some struts with a ribbed bowl sort of thing below the top mount and some don't have this. Just wanna check mine does and replace it if needed. Cheers
The Springs are on a separate diagram:
Let me know item numbers
howardaskew
x 9
C5 X7 Wishbones are there different types?
Good morning.
Reason: Post moved to the Parts thread
