C4 Picasso 2014 Exclusive - Air Con Fan Issue (new Shape)
zane2g2
Unread post by zane2g2 »
Good afternoon all
First thing I must say, is what a brilliant site this is :-)
Onto my issue that I hope some very technically based people will be able to help me with :-)
On my 2014 C4 Pic (new shape) I have an issue with the cabin/air con heater fan unit.
Basically no matter what setting I have the speed on (from off to full tilt) the fan stays at the same speed.
When I turn up or down the temperature the fan stays the same speed.
Also when I unlock the car the fan starts running.
When I lock the car, the fan keeps running for a few minutes after locking.
I suspect its some kind of relay problem.
Can anyone assist in showing a schematic of where and/or how to remove/replace the resistor.
Or other any other advise into what is going on.
Many thanks
Zane
x 1955
Re: C4 Picasso 2014 Exclusive - Air Con Fan Issue (new Shape)
Unread post by Paul-R »
It's definitely the fan for the heater/aircon you mean? Not the radiator cooling fan?
zane2g2
Hi Paul,
Yep definitely the aircon/heater fan.
I had the bonnet open and checked whilst the fan was running.
Plus the fan noise was coming from the bulk head area of the engine bay.
Cheers
Zane
Paul-R wrote: 27 Aug 2019, 13:18 It's definitely the fan for the heater/aircon you mean? Not the radiator cooling fan?
zane2g2
just wondering if anyone has further they could assist me with please
x 1486
Unread post by xantia_v6 »
You say the fan runs at a constant speed, is running fast or slow?
It is quite likely the speed controller module that has failed, but a better description might help us.
x 1506
The fan appears to be in the driver's footwell, so it seems a bit unlikely that you can hear it with the bonnet open....
The controller is next to the blower unit, I suspect that getting to it on a RHD car might be a bit of a challenge!!
zane2g2
Hi guys....
So...
It’s definitely the air con/heater fan
It can be heard on the out side and is definitely at the back of the engine bay
The speed of the fan is at constant fast speed
No matter what what speed or temperature I set on the touch screen air con page the fan stays at the same high speed.
Would any one have a diagram of the heat unit or any instruction on how to access said area.
I really appreciate all of your inputs
Cheers
x 6950
Not you've said it is running constantly on fast speed, that would very likely be the lower Control Module.
Pop your VIN up for further details so we know the exact system you have.
x 1486
GiveMeABreak wrote: 28 Aug 2019, 10:23 Not you've said it is running constantly on fast speed, that would very likely be the lower Control Module.
Time to get a new keyboard Marc?
x 6950
Indeed! Blower not Lower^
Autocorrect getting it wrong as usual!
x 5689
GiveMeABreak wrote: 28 Aug 2019, 10:41 Indeed! Blower not Lower^
Now, not Not too :)
You would be shocked at the amount of red squiggly lines I get, usually additional or missing letters but often words spelled completely back to front.
Sometimes the spellcheck suggestions are hilarious - I don't have autocorrect, fortunately.
x 6950
It's worse when using any of the iPads or iPhones - on the PC it's just me! - But I do cycle through 3 keyboards depending on the RSI factor.
x 5689
I don't use tablets, don't like them at all and my phone is too thick to use on t'internet. Too small too, I can barely see to text.
x 1506
There looks to be only 1 type of blower and controller for all Mk2 cars.
Blower removal
Controller is next to the blower on the ducting, this is removing on a LHD car where it's behind the glovebox, it looks like it will be visible once the panel is removed as per stage 3 above.
zane2g2
Hi Marc,
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Hope this helps and thank you to every one for their help.
