Lucas EPIC Injection Pump Overhaul Guide
Myppi
moizeau
- x 423
Re: Lucas EPIC Injection Pump Overhaul Guide
Sorry, no idea. I don't recognise it at all, don't think there any rectangular pieces in there. I've just checked my factory service manual and it doesn't show it in any of the exploded views.
This is a PSA Lucas Epic pump?
Pete
wesacosa
- (Donor 2021)
- x 3
Hi all
I am not sure if I have misdiagnosed the source of my leak. I had it in my mind it was the four O rings under the solenoid block where it attaches to the pump body but I have just looked again at a video I took last year when I last used the car and its gathering here (red arrow is on a stock picture and yellow circle is a freeze frame of the video of my car showing the fuel pooling) I am now wondering if this is above the height of those o rings and hence is coming from the o rings inside the solenoid mechanism and not where the block fits onto the pump body
moizeau
- x 423
The 2nd photo is 90 degs out, couldn't work it out at first. Yep, quite possibly, easy to do in situ. Without rereading this thread I'm sure I posted how to and O ring sizes.
Pete
wesacosa
- (Donor 2021)
- x 3
Ok thanks I will take a look. I had only been reading about the procedure for changing the bottom o rings as I thought that was the source but will look back to see if I can find anything on the top/internal o rings. I think I remember a PDF in french showing that on an earlier post too
moizeau
- x 423
Pete
wesacosa
- (Donor 2021)
- x 3
thanks. I will have another look tomorrow to see if its leaking from the top or if its leaking from the bottom spilling over the base. pretty sure the seal kit I have doesn't have the internal o rings for the solenoids
moizeau
- x 423
No it won't. This is not supposed to be serviceable (along with some other bolt on bits of electrickery), officially it should be replaced. The O ring sizes are stated in the link. Any decent bearing supplier will stock them.
Pete
wesacosa
- (Donor 2021)
- x 3
Hmm the O ring size just gives one diameter but doesn't say if its OD or ID
moizeau
- x 423
O rings are always ID and core thickness
Pete
wesacosa
- (Donor 2021)
- x 3
thanks that's what I would have guessed but wasn't sure.. will get a set ordered
wesacosa
- (Donor 2021)
- x 3
Hi
Does anyone know if the rear plastic cover can be removed in situ or will it not pass the feed pipe nuts? I took the top cover off but I couldn't see what was holding the rear part on
I'm trying to see where my leak is coming from before I plan my next move and I think it's somewhere under that cover
cheers
cheers
ds23pa
Himoizeau wrote: 21 Feb 2023, 09:42 No, mark it's position on it's mounting plate and replace it in the same place. Do you want a Lucas Epic repair manual? If so PM me your email and I'll send it you.
Didn't find any way to PM. Is it the french manual or do You got an english version. If so I'm interested
moizeau
- x 423
The rear cover is held on with a single central screw from memory. You need to take the injector pipes off to remove it....again from memory so I might be talking cobblers. Pretty sure I didn't bother putting it back on the rebuild. It was years ago that I did this.
https://www.dropbox.com/scl/fi/d06o2tpq ... x3wcu&dl=0
This is a link to a dropbox pdf, English version.
Pete
ds23pa
Thanks!moizeau wrote: 02 Jun 2024, 13:05
