C4 Pedal spacing
the2ems
- x 10
C4 Pedal spacing
Been driving the C4 for two weeks now, and struggling with foot placement on the clutch pedal. I keep catching the “foot rest” to the left, or the brake pedal to the right, more so when braking at the same time. It’s never taken me this long to get used to a car before. Anyone else had the same problem? Any advice?
CITROEN C4 1.2 PURETECH C-SERIES EDITION S/S 5DR (2023)
- x 8152
Re: C4 Pedal spacing
That problem does beg the question what size and type of shoes are you using?
the2ems
- x 10
- x 8152
Same size as me, I had similar issues many years ago with my brother-in-laws Renault 4. I used to wear my yachting deck shoes which were about as slim as I owned to make it easier. However I have heard of people taking the angle grinder to trim the brake pedal and footrest but I don't know if that is possible in a C4.
the2ems
- x 10
mickthemaverick wrote: 02 Mar 2024, 21:12 Same size as me, I had similar issues many years ago with my brother-in-laws Renault 4. I used to wear my yachting deck shoes which were about as slim as I owned to make it easier. However I have heard of people taking the angle grinder to trim the brake pedal and footrest but I don't know if that is possible in a C4.![]()
- x 6948
the2ems
- x 10
Really? It’s my only issue with the car so far (apart from the failed update, which is now fixed) Maybe it’s designed for ladiesGiveMeABreak wrote: 02 Mar 2024, 23:44 Seems the old C4 suffered the same issue.....
viewtopic.php?p=791368#p791368
the2ems
- x 10
After 6 months and 1500 miles, I still have the same problem with the pedal spacing. Maybe if the useless foot rest under the clutch pedal were not there
- x 6948
Maybe a pair of these?
the2ems
- x 10
Vic Evans
- x 177
Mrs Vic has owned a C4 for 10 years since new.
I've driven it thousands of Kms & never given the pedal spacings a thought apart from thinking I actually like the foot rest.
Maybe it's because it's lhd ?
I've size 8 feet & drive locally in Crocs & distances in Sketchers.
the2ems
- x 10
Maybe they changed the spacing on later models
. I can’t even get my foot on the rest without first moving it backwards, then going under the clutch pedal and forward again. Certainly can’t just do a side and down movement from the clutch.
