PSA NAC RCC Updates
- x 6946
Re: PSA NAC RCC Updates
Firmware 44.07.05.22_NAC-r0
declan_2001 Licence File
Map V15
Read other posts about creation of licence folder and exactly what to extract onto USB.
Map V15
declan_2001
great would i just download this onto my USB and plug it into the car?
- x 6946
Kaiw90
Hello. I am having the same issues with my Citroen C3 update when trying to download the update from 'Citroen Update'.
Can I please have the files too?
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Thank you!!
Karol
Thank you!!
Karol
- x 6946
gunnariator
- New User
Hello i am habibi troubadour connecting my phone using a usb. The iPod icon doesn’t turn white. I am unsure if it needs an update
Thanks in advance
Thanks in advance
- x 6946
@gunnariator
You will need to provide your VIN before I can check whether there is an update for you.
maki3661
Hi @GiveMeABreak ,
Recently I bought Citroen C5 Aircross 2019, and I would like to update my nav system, but the official Citroen app isn't working properly, it wont let me download the update. Could you please provide me the update file somehow? My VIN is VR7**************[VIN obfuscated, can be read by forum staff]
Thanks in advance.
Thanks in advance.
- x 6946
maki3661
@GiveMeABreak
Unfortunately I have another issue, because my system version is too old (31.09.46.62), it fails to update. Do you have a firmware update thats between those two?
- x 6946
It won't make any difference because you have a Wave 3 system on Wave 3 Firmware.
The next 2 updates convert the system to Wave 4, so is a double purpose type of firmware. There are only two versions above your existing version, and they are very large updates to do the conversion, so you will have the same issue.
Make sure you have a large enough USB, correctly FAT 32 formatted and that only the extracted files and folders are on the USB and make sure that you are in a location where the WiFi can pick up a signal to authorise the update. If not here is the licence file:
Create a folder called license on the USB and copy the licence file into that folder.
Maki3661 Licence File
The update is about 22 Gb, so use a 32 Gb USB
dazzler33d
- New User
Hi All
hope you can help me
i recently purchased a 2017 C4 Picasso and i need to update the touch screen
i have downloaded the update too and it shows i need the update version 1_076_16.1b116.4 l but get a message of - "error retrieving data"
i have seen on this thread if i post my vin number someone might be able to help me
M_Vigne
- New User
Hi, I've the same problem when trying to download the update from 'Citroen Update'
Please can I have the files too?
VIN VF7**************[VIN obfuscated, can be read by forum staff], Citroen C3
Thanks in advance for your help!
Manuel
Manuel
- x 6946
Cinar
Hello. I am having the same issues with my Citroen C3 Aircorss update when trying to download the update from 'Citroen Update'.
Thank you!!
Thank you!!
