Torque setting
Barney00731102012
Torque setting
Unread post by Barney00731102012 »
Hi everyone
I’m new to here , but I’m hoping someone can help me who has knowledge or advice. Ok here goes, I’ve just purchased a Peugeot Boxer 1.9td 2001 camper with the XUD 9UTF engine. I’ve just changed the timing belt and finding it difficult to find torque settings. I’ve done as per a manual I’ve purchased the bottom crankshaft bolt to 30lbft followed by 60 degree and loctite on the thread. For some reason a couple of days later the bolt has worked loose, so I’m hoping someone might have the correct settings.
x 6956
Re: Torque setting
Sorry, but I personally don't have the specific data you need for this vehicle, being as it is quite early and the paper-based info wasn't all transferred over to the later systems.
x 1866
Re: Torque setting
Could the torque figure have been 30 Nm not lbft?
x 1044
Re: Torque setting
Unread post by wheeler »
According to Autodata it should be 40 Nm + 51 degrees
perrye
x 10
Re: Torque setting
Unread post by perrye »
Haynes says 40 Nm+60 degrees
Barney00731102012
Re: Torque setting
Just wanted to thank everyone who took the time to reply to my post, in regards to the crankshaft bolt torque setting, it’s much appreciated.
